MacBook Pro 13" Touch Bar 2018 Battery Replacement
    1. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Disable Auto Boot: step 1, image 1 of 3 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Disable Auto Boot: step 1, image 2 of 3 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Disable Auto Boot: step 1, image 3 of 3
      • Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot. This command may not work on all Macs.
      • Power on your Mac and launch Terminal.
      • Copy and paste the following command (or type it exactly) into Terminal:
      • sudo nvram AutoBoot=%00
      • Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
      • You can now safely power down your Mac and open the bottom case, without it accidentally powering on.
      • When your repair is complete and your Mac is successfully reassembled, re-enable Auto Boot with the following command:
      • sudo nvram AutoBoot=%03
      Ask FixBot
    1. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Remove the pentalobe screws: step 2, image 1 of 1
      Tool used on this step:
      Magnetic Project Mat
      $19.95
      Buy
      • Before proceeding, unplug and power down your MacBook. Close the display and lay it on a soft surface, top-side down.
      • Use a P5 Pentalobe driver to remove the six screws securing the lower case:
      • Two 6.2 mm screws
      • Four 3.4 mm screws
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
      Ask FixBot
    2. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Open a gap using a suction cup: step 3, image 1 of 2 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Open a gap using a suction cup: step 3, image 2 of 2
      • Apply a suction handle to the lower case near the front-center area of the MacBook Pro.
      • Lift the suction handle to create a slight gap between the lower case and the chassis.
      Ask FixBot
    3. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Separate the clips: step 4, image 1 of 3 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Separate the clips: step 4, image 2 of 3 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Separate the clips: step 4, image 3 of 3
      • Insert one corner of an opening pick into the space between the lower case and the chassis.
      • Slide the opening pick around the nearest corner and halfway up the side of the case.
      • This releases the first of the hidden clips securing the lower case to the chassis. You should feel and hear the clip pop free.
      Ask FixBot
    4. MacBook Pro 13" Touch Bar 2018 Battery Replacement: step 5, image 1 of 3 MacBook Pro 13" Touch Bar 2018 Battery Replacement: step 5, image 2 of 3 MacBook Pro 13" Touch Bar 2018 Battery Replacement: step 5, image 3 of 3
      • Repeat the previous step on the opposite side, sliding your opening pick under the lower case and up the side to pop the second clip free.
      Ask FixBot
    5. MacBook Pro 13" Touch Bar 2018 Battery Replacement: step 6, image 1 of 3 MacBook Pro 13" Touch Bar 2018 Battery Replacement: step 6, image 2 of 3 MacBook Pro 13" Touch Bar 2018 Battery Replacement: step 6, image 3 of 3
      • Insert your opening pick once again under the front edge of the lower case, near one of the two centermost screw holes.
      • Give the pick a firm twist to pop free the third clip securing the lower case to the chassis.
      • Repeat this procedure near the other of the two centermost screw holes, popping the fourth clip free.
      Ask FixBot
    6. MacBook Pro 13" Touch Bar 2018 Battery Replacement: step 7, image 1 of 3 MacBook Pro 13" Touch Bar 2018 Battery Replacement: step 7, image 2 of 3 MacBook Pro 13" Touch Bar 2018 Battery Replacement: step 7, image 3 of 3
      • Pull the lower case firmly towards the front of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
      • Pull first at one corner, then the other.
      • Pull to the side—not up.
      • This can require a lot of force.
      Ask FixBot
    7. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Remove the lower case: step 8, image 1 of 3 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Remove the lower case: step 8, image 2 of 3 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Remove the lower case: step 8, image 3 of 3
      • Remove the lower case.
      • To reinstall the lower case:
      • Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
      • When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
      Ask FixBot
    1. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Uncover the battery connector: step 9, image 1 of 2 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Uncover the battery connector: step 9, image 2 of 2
      • Carefully peel up the large piece of tape covering the battery connector, on the edge of the logic board nearest the battery.
      • Remove the tape.
      Ask FixBot
    2. MacBook Pro 13" Touch Bar 2018 Battery Replacement: step 10, image 1 of 2 MacBook Pro 13" Touch Bar 2018 Battery Replacement: step 10, image 2 of 2
      • Gently peel back the small piece of tape covering the battery board data cable connector.
      • The tape is integrated into the ribbon cable and will not detach completely. Simply peel it back enough to access the connector.
      Ask FixBot
    3. MacBook Pro 13" Touch Bar 2018 Battery Replacement: step 11, image 1 of 2 MacBook Pro 13" Touch Bar 2018 Battery Replacement: step 11, image 2 of 2
      • Use the tip of a spudger to flip up the small black locking tab securing the cable in its connector.
      Ask FixBot
    4. MacBook Pro 13" Touch Bar 2018 Battery Replacement: step 12, image 1 of 2 MacBook Pro 13" Touch Bar 2018 Battery Replacement: step 12, image 2 of 2
      • Disconnect the battery board data cable by sliding it out from its socket.
      • Slide parallel to the logic board, in the direction of the cable.
      Ask FixBot
    5. MacBook Pro 13" Touch Bar 2018 Battery Replacement: step 13, image 1 of 2 MacBook Pro 13" Touch Bar 2018 Battery Replacement: step 13, image 2 of 2
      • Fold the battery board data cable to the side and out of the way.
      Ask FixBot
    6. MacBook Pro 13" Touch Bar 2018 Battery Replacement: step 14, image 1 of 1
      • Use a T5 Torx driver to remove the 3.7 mm pancake screw securing the battery power connector.
      Ask FixBot
    7. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Disconnect the battery: step 15, image 1 of 2 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Disconnect the battery: step 15, image 2 of 2
      • Use a spudger to gently lift the battery power connector, disconnecting the battery.
      • Lift the connector high enough so that it stays separated from its socket. If it accidentally makes contact during the course of your repair, it could damage your MacBook Pro.
      Ask FixBot
    1. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Remove the trackpad connector screws: step 16, image 1 of 1
      • Use a T3 Torx driver to remove the two 1.8 mm screws securing the trackpad cable connector bracket.
      Ask FixBot
    2. MacBook Pro 13" Touch Bar 2018 Battery Replacement: step 17, image 1 of 1
      Buy
      • Remove the trackpad cable connector bracket with a pair of tweezers.
      Ask FixBot
    3. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Disconnect the trackpad: step 18, image 1 of 2 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Disconnect the trackpad: step 18, image 2 of 2
      • Use a spudger to disconnect the trackpad ribbon cable by gently prying its connector straight up from the logic board.
      Ask FixBot
    4. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Heat the trackpad cable: step 19, image 1 of 1
      • Prepare an iOpener and lay it on top of the trackpad ribbon cable for about a minute, in order to soften the adhesive securing the trackpad ribbon cable to the top of the battery.
      • If you don't have an iOpener, use a hair dryer to warm up the cable instead. The cable should be warm, but not too hot to touch. Be careful not to overheat the battery.
      Ask FixBot
    5. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Peel up the trackpad cable: step 20, image 1 of 3 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Peel up the trackpad cable: step 20, image 2 of 3 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Peel up the trackpad cable: step 20, image 3 of 3
      • Carefully peel the trackpad ribbon cable up off the battery, and push it out of the way.
      • Do not fold or tear the cable.
      Ask FixBot
    6. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Remove the trackpad screws: step 21, image 1 of 1
      • Use a T5 Torx driver to remove the ten screws securing the trackpad assembly:
      • Two 4.3 mm screws
      • Eight 5.8 mm screws
      Ask FixBot
    7. MacBook Pro 13" Touch Bar 2018 Battery Replacement: step 22, image 1 of 2 MacBook Pro 13" Touch Bar 2018 Battery Replacement: step 22, image 2 of 2
      • Swing the display open slightly to access the trackpad.
      • Carefully thread the trackpad ribbon cable out through the hole in the MacBook Pro's frame.
      Ask FixBot
    8. MacBook Pro 13" Touch Bar 2018 Battery Replacement: step 23, image 1 of 3 MacBook Pro 13" Touch Bar 2018 Battery Replacement: step 23, image 2 of 3 MacBook Pro 13" Touch Bar 2018 Battery Replacement: step 23, image 3 of 3
      • Remove the trackpad assembly.
      • Be sure not to lose the six small washers (two circular and four rectangular) resting on the underside of the trackpad.
      Ask FixBot
    1. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Unscrew the battery board: step 24, image 1 of 1
      • Use a T5 Torx driver to remove the two 3.2 mm screws from the battery board.
      Ask FixBot
    2. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Protect the display and keyboard: step 25, image 1 of 3 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Protect the display and keyboard: step 25, image 2 of 3 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Protect the display and keyboard: step 25, image 3 of 3
      • The liquid adhesive remover provided in your kit can cause damage if it contacts the MacBook Pro's display or keyboard.
      • To protect your display, place a sheet of aluminum foil between the display and keyboard and leave it there while you work.
      • Additionally, use some tape and/or foil to seal off the area under the trackpad. Optionally, you may also layer an absorbent towel directly underneath the trackpad area to soak up any excess adhesive remover.
      Ask FixBot
    3. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Protect the speakers: step 26, image 1 of 1
      • Before removing the battery, it's important to protect the speakers on either side. The speakers are glued down just like the battery—so if the liquid adhesive remover gets under the speakers, they may come loose and rattle after your repair.
      • Cut a length of packing tape or painter's tape, and slide one edge between the battery and the speaker on the left side.
      Ask FixBot
    4. MacBook Pro 13" Touch Bar 2018 Battery Replacement: step 27, image 1 of 3 MacBook Pro 13" Touch Bar 2018 Battery Replacement: step 27, image 2 of 3 MacBook Pro 13" Touch Bar 2018 Battery Replacement: step 27, image 3 of 3
      • Press all along the edge of the tape with your spudger to stick it securely to the MacBook Pro's aluminum case, sealing off the speaker from the battery.
      • Be careful not to poke or puncture the battery.
      • Fold the tape over and lightly adhere it to the speaker to keep it out of the way.
      • The foam bumpers on top of the speaker may tear when peeling the tape off. Don't press the tape directly onto the bumpers.
      Ask FixBot
    5. MacBook Pro 13" Touch Bar 2018 Battery Replacement: step 28, image 1 of 1
      • Repeat the previous two steps on the opposite side in order to seal off the other speaker from the battery.
      Ask FixBot
    6. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Elevate the right edge: step 29, image 1 of 3 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Elevate the right edge: step 29, image 2 of 3 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Elevate the right edge: step 29, image 3 of 3
      • To control the flow of adhesive remover and direct it away from the speaker, raise the right edge of your MacBook Pro a few inches using a book or foam block.
      Ask FixBot
    7. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Protect your eyes and skin: step 30, image 1 of 2 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Protect your eyes and skin: step 30, image 2 of 2
      • Now that your MacBook Pro is fully prepped, it's time to prep yourself.
      • iFixit adhesive remover contains acetone, a mild skin and eye irritant.
      • Wear eye protection when handling and applying the adhesive remover. (Eye protection is included in your kit.)
      • Do not wear contact lenses without eye protection.
      • Protective gloves are also included in your kit. If you are concerned about possible skin irritation, put your gloves on now.
      Ask FixBot
    8. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Open the adhesive remover: step 31, image 1 of 3 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Open the adhesive remover: step 31, image 2 of 3 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Open the adhesive remover: step 31, image 3 of 3
      • Pull off the black rubber stopper from your bottle of adhesive remover.
      • Twist to loosen or remove the bottle cap before you cut the applicator tip.
      • This unseals the bottle and allows the pressure to equalize before you cut the applicator tip. If you skip this step, the adhesive remover may spray out unexpectedly when the tip is cut.
      • Use scissors to cut off the sealed tip of the applicator.
      • Cutting close to the narrow tip will give you better control so you can apply the adhesive remover in small amounts.
      • Twist and close the bottle cap securely before you proceed further.
      Ask FixBot
    9. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Apply the adhesive remover: step 32, image 1 of 3 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Apply the adhesive remover: step 32, image 2 of 3 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Apply the adhesive remover: step 32, image 3 of 3
      • Apply a few drops of adhesive remover underneath the far right battery cell.
      • You don't need to use very much—the small bottle contains more than twice the amount of solvent needed to remove all the battery cells.
      • Wait about two minutes for the adhesive remover to penetrate and soften the battery adhesive before you proceed to the next step.
      Ask FixBot
    10. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Separate the outside right battery cell: step 33, image 1 of 3 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Separate the outside right battery cell: step 33, image 2 of 3 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Separate the outside right battery cell: step 33, image 3 of 3
      Plastic Cards
      $2.99
      Buy
      • After a couple minutes, insert one corner of a plastic card underneath the far right battery cell, starting from the front edge.
      • This shouldn't require much force. If you have trouble, apply more adhesive remover and give it 2-3 additional minutes to penetrate.
      • Try not to deform the battery. A damaged battery can leak dangerous chemicals and/or catch fire.
      • Wiggle the card from side to side and slide it all the way under the battery cell.
      • Lift to fully separate the adhesive, but don't try to remove the battery cell yet.
      • Leave the plastic card temporarily underneath the cell to prevent it from re-adhering while you continue.
      Ask FixBot
    11. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Alternative: separate the battery cell with floss: step 34, image 1 of 1
      • If you have difficulty getting the card underneath any of the battery cells, try working a piece of floss or wire underneath the battery cell. Pull it side-to-side in a sawing motion to separate the adhesive.
      • Wear thick gloves or wrap the floss around a couple of driver handles so as not to hurt your fingers.
      Ask FixBot
    12. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Elevate the left edge: step 35, image 1 of 2 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Elevate the left edge: step 35, image 2 of 2
      • Repeat the last few steps to separate the far left battery cell.
      • Begin by elevating the left side of the MacBook Pro to direct the flow of adhesive remover away from the speaker.
      Ask FixBot
    13. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Apply adhesive remover: step 36, image 1 of 3 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Apply adhesive remover: step 36, image 2 of 3 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Apply adhesive remover: step 36, image 3 of 3
      • Apply a few drops of adhesive remover under the far left battery cell, and wait about two minutes for it to penetrate.
      Ask FixBot
    14. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Separate the outer left cell: step 37, image 1 of 2 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Separate the outer left cell: step 37, image 2 of 2
      • Slide one corner of a plastic card underneath the far left battery cell, and carefully separate the adhesive holding it in place.
      Ask FixBot
    15. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Elevate the back edge: step 38, image 1 of 1
      • Next, raise the back edge of your MacBook Pro to direct the flow of adhesive remover away from the keyboard/logic board area.
      Ask FixBot
    16. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Apply adhesive remover: step 39, image 1 of 3 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Apply adhesive remover: step 39, image 2 of 3 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Apply adhesive remover: step 39, image 3 of 3
      • Apply a few drops of adhesive remover under each of the remaining three battery cells.
      • There are openings in the aluminum case underneath these cells, so some of the adhesive remover may leak out instead of penetrating underneath the battery.
      • Be mindful of leaks, and apply more adhesive remover in the following steps if needed.
      • Wait about two minutes before you continue.
      Ask FixBot
    17. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Separate the inner left cell: step 40, image 1 of 3 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Separate the inner left cell: step 40, image 2 of 3 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Separate the inner left cell: step 40, image 3 of 3
      • The remaining two smaller battery cells each sit on a slightly raised portion of the MacBook's aluminum frame.
      • Slide a plastic card all the way underneath the far left battery cell—which you already separated in the previous steps—and then insert it carefully between the remaining left-side battery cell and the MacBook Pro's aluminum case.
      Ask FixBot
    18. MacBook Pro 13" Touch Bar 2018 Battery Replacement: step 41, image 1 of 2 MacBook Pro 13" Touch Bar 2018 Battery Replacement: step 41, image 2 of 2
      • Use your plastic card to fully separate the remaining battery cell on the left side.
      • Take care to not pry against the logic board.
      • Leave your plastic card in place temporarily to prevent the left-side battery cells from re-adhering.
      Ask FixBot
    19. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Separate the inner right cell: step 42, image 1 of 3 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Separate the inner right cell: step 42, image 2 of 3 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Separate the inner right cell: step 42, image 3 of 3
      • Repeat the previous two steps to separate the remaining battery cell on the right.
      Ask FixBot
    20. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Separate the middle cells: step 43, image 1 of 3 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Separate the middle cells: step 43, image 2 of 3 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Separate the middle cells: step 43, image 3 of 3
      • The final battery cells can be more difficult to remove. If needed, apply more adhesive remover to make the job easier.
      • Slide the corner of one of your plastic cards underneath the top edge of one of the cells and then work it underneath the other cell.
      • Wiggle the card from side to side and slide it underneath the battery cells to fully separate the adhesive holding them in place.
      Ask FixBot
    21. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Remove the battery: step 44, image 1 of 3 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Remove the battery: step 44, image 2 of 3 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Remove the battery: step 44, image 3 of 3
      Buy
      • Before you remove the battery, ensure that the battery connector is sufficiently raised and not in the way of the battery board.
      • Remove the battery.
      • Before installing a new battery, remove all remaining adhesive from the MacBook Pro's case.
      • Peel off any large strips of adhesive using tweezers or gloved fingers.
      • Scrape away any remaining chunks of adhesive with a plastic tool, and clean the underlying areas with adhesive remover or isopropyl alcohol. Wipe in one direction (not back and forth) until the chassis is clean and ready for your new battery.
      • This can take quite a bit of work, so be patient.
      • When you're done, carefully remove the protective tape from the speakers.
      Ask FixBot
    22. MacBook Pro 13" Touch Bar 2018 Battery Replacement, Battery installation: step 45, image 1 of 3 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Battery installation: step 45, image 2 of 3 MacBook Pro 13" Touch Bar 2018 Battery Replacement, Battery installation: step 45, image 3 of 3
      Tesa 61395 Tape
      $25.95
      Buy
      • Double-check the fit and alignment of your new battery before sticking it down.
      • Be mindful of the battery data cable and make sure it doesn't get pinched or trapped under the battery board.
      • If your battery came with adhesive pre-installed on the bottom, flip it over and carefully peel away the liner to expose the adhesive. If your battery did not come with adhesive, apply a thin double-sided adhesive tape such as Tesa 61395 to keep your battery in place.
      • Carefully position the battery and set it into place.
      • Place the battery close to the logic board so the trackpad cable can reach its connector.
      • Press and hold each cell firmly for 5-10 seconds to secure it to the lower case.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
68 other people completed this guide.
Tarun Thiruma
40,615 Reputation
133 Guides authored
24 Guide Comments
When remounting, putting back the trackpad in a nicely centered position can become a lengthy exercise of patience.
I haven’t find guides or tricks to help; the best I came up with was to
* put back just two corner screws, without tightening them, that is enough to keep it in place and not lose the washers
* flip back your macbook keyboard up
* center the trackpad and fix it in place with adhesive tape
* flip it back belly-up, tighten the two corner screws and add the remaining six.
Sergio Ballestrero - Reply Share
Thanks; everything went well, except at the end I realized that I somehow damaged the battery connector from step 12/13. What is the part number, please?
Brian Jackson - Reply Share
The replacement went very smoothly, and when I re-assembled the laptop, the spacebar and command keys seemed tight. Any thoughts about how that might happen?
JNM - Reply Share
Der Akkutausch funktioniert auch mit dem Heißluftfön bei max. 100° Celsius…
Einfach die Akku-Sektionen dazu eine Minute etwas erwärmen und dann mit der Karte den Klebstoff lösen!
Der Einbau des Trackpads ist etwas fummelig da es beim Zentrieren keine Arretierung oder ähnliches gibt, dazu am besten einige Schrauben etwas anziehen und dann systematisch festziehen! Ich legte das aufgeklappte MacBook über einen Überhang damit ich von oben das Trackpad immer justieren konnte und mit der anderen Hand schraubte ich von unten die Schrauben fest ;-)
Bruce Kungfuzius - Reply Share
I fixed it! My original battery had swollen badly and had been a fire hazard.
This was my first time fixing a phone / laptop. Instructions were quite clear and easy to follow. I didn't run into any problem.
Very proud of myself at the moment ☺️
Haoxue Wang - Reply Share
Past 24 Hours: 47
Past 7 Days: 474
Past 30 Days: 1,940
All Time: 151,215
