Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
No Wi-Fi Network
The router is not providing a Wi-Fi network.
Router Turned Off
Make sure that the power cord is connected to the router. When turning on the router confirm that the Wi-Fi LED is a solid instead of flashing. The router may need a factory reset. Press the red reset button to bring the router to factory settings. If the reset button needs to be replaced, use our Reset Button Replacement guide
Ethernet Cable Disconnected
Confirm that the Ethernet cable is connected to the router from the cable modem. Make sure that the cable is connected to the yellow internet port on the router.
Router Not Turning On
The router is not powering on when connected to an outlet.
Loose Connection
Ensure that the power cable is securely connected to both the device and wall outlet. Try different power outlets to rule out a faulty outlet. Move the cable around while connected to the router, if power goes on and off then the cable may be faulty and will need to be replaced. If the router does not turn on at any moment then the power port is faulty. You can replace the power port using our Power Port Replacement guide.
No Internet via Ethernet Connection
When connected to the Ethernet port, the user is unable to establish an internet connection.
Faulty Ethernet Cable
Connect a different Ethernet cable into the same Ethernet port. If the connection is established with the new cable, the original cable used is faulty.
Faulty Ethernet Port
Using the same Ethernet cable test the other three ports. If an internet connection is established with the other three ports, then the original port is faulty. You can replace the Ethernet ports using our Ethernet Port Replacement guide.
No USB Connectivity
Unable to receive power or data transfer via USB ports.
Faulty USB Cable
Connect another USB cable to the original USB port. If a connection is established using the new cable, the original cable is faulty.
Faulty USB Port
Using a working USB 2.0 cable, test the other port for connectivity. If power or data transfer is successful then the original port is faulty. You can replace the USB port using our USB Ports Replacement guide.
Antennas Not Staying In Place
The antennas do not remain stable and in a fixed position.
The Threads On The Antennae Are Stripped
Check the threading on the inside of each antennae to determine if a replacement antennae may be necessary. Use this Antenna Replacement guide if new antenna components are needed.
The Screw Attached To The Router Is Stripped
A replacement screw may be necessary if the screw is stripped.
Rick Hsu
355 Reputation
1 Guide authored
USF Tampa, Team 11-1, Blackwell Fall 2016 Member of USF Tampa, Team 11-1, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G1
4 Members
72 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 23
All Time: 3,103
