Up to 20% off select tools
Ethernet Port Replacement
Views: 9.3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
36
Past 30 Days:
157
All Time:
9,295
Comments: 1
1 guide comment.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 40 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will teach you how to access the motherboard in order to replace the Ethernet ports.
    1. Ethernet Port Replacement, Linksys EA6900 Disassembly: step 1, image 1 of 3 Ethernet Port Replacement, Linksys EA6900 Disassembly: step 1, image 2 of 3 Ethernet Port Replacement, Linksys EA6900 Disassembly: step 1, image 3 of 3
      Tool used on this step:
      Buy
      • Remove the antennas by unscrewing them from the base.
      • Flip over the device and locate the four rubber feet on the bottom.
      • Remove the rubber feet with tweezers
      Ask FixBot
    2. Ethernet Port Replacement: step 2, image 1 of 1
      • Remove the 0.4cm head screws from each slot with the #1 Phillips head Screwdriver.
      Ask FixBot
    3. Ethernet Port Replacement: step 3, image 1 of 1
      • Use a blue plastic opening tool to remove the top cover.
      • Move the blue plastic opening tool gently underneath the top cover from side to side.
      Ask FixBot
    4. Ethernet Port Replacement: step 4, image 1 of 3 Ethernet Port Replacement: step 4, image 2 of 3 Ethernet Port Replacement: step 4, image 3 of 3
      • Gently lift the motherboard and remove it from the case
      • Put the motherboard over a (preferably white) surface.
      Ask FixBot
    1. Ethernet Port Replacement, Ethernet Ports: step 5, image 1 of 3 Ethernet Port Replacement, Ethernet Ports: step 5, image 2 of 3 Ethernet Port Replacement, Ethernet Ports: step 5, image 3 of 3
      • Locate the Ethernet ports
      • Flip the motherboard and locate the 40 solder points corresponding to the Ethernet ports
      • Melt the 40 solder points using a soldering gun.
      • Wait between five and seven minutes for the ports to cool down.
      Ask FixBot
    2. Ethernet Port Replacement: step 6, image 1 of 1
      • Hold the motherboard down and use the spudger to remove the Ethernet Ports.
      Ask FixBot
6 other people completed this guide.
Author
with
Denis
611 Reputation
3 Guides authored
USF Tampa, Team 11-1, Blackwell Fall 2016 Member of USF Tampa, Team 11-1, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G1
4 Members
72 Guides authored
1 Guide Comment
Can you make a guide to replace the antenna base connector, mine get broken at the base, I wonder if it is possible to make the cable connection directly to the antenna, does that could work?
Enrique Jendrix - Reply Share
Past 24 Hours: 4
Past 7 Days: 36
Past 30 Days: 157
All Time: 9,295
