Linksys EA6900 Power Port Replacement
  1. Linksys EA6900 Power Port Replacement, Linksys EA6900 Disassembly: step 1, image 1 of 3 Linksys EA6900 Power Port Replacement, Linksys EA6900 Disassembly: step 1, image 2 of 3 Linksys EA6900 Power Port Replacement, Linksys EA6900 Disassembly: step 1, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the antennas by unscrewing them from the base.
    • Flip over the device and locate the four rubber feet on the bottom.
    • Remove the rubber feet with tweezers
    Ask FixBot
  2. Linksys EA6900 Power Port Replacement: step 2, image 1 of 1
    • Remove the 0.4cm head screws from each slot with the #1 Phillips head Screwdriver.
    Ask FixBot
  3. Linksys EA6900 Power Port Replacement: step 3, image 1 of 1
    • Use a blue plastic opening tool to remove the top cover.
    • Move the blue plastic opening tool gently underneath the top cover from side to side.
    Ask FixBot
  4. Linksys EA6900 Power Port Replacement: step 4, image 1 of 3 Linksys EA6900 Power Port Replacement: step 4, image 2 of 3 Linksys EA6900 Power Port Replacement: step 4, image 3 of 3
    • Gently lift the motherboard and remove it from the case
    • Put the motherboard over a (preferably white) surface.
    Ask FixBot
  5. Linksys EA6900 Power Port Replacement, Power Port: step 5, image 1 of 2 Linksys EA6900 Power Port Replacement, Power Port: step 5, image 2 of 2
    • Locate the power port on both sides of the motherboard.
    • The power port on the top side is in a rectangular black casing.
    • Identify the three prongs where the power port is soldered to on the reverse side.
    Ask FixBot
  6. Linksys EA6900 Power Port Replacement: step 6, image 1 of 3 Linksys EA6900 Power Port Replacement: step 6, image 2 of 3 Linksys EA6900 Power Port Replacement: step 6, image 3 of 3
    • Carefully apply the soldering iron on each of the three points on the bottom side of the motherboard to melt them.
    • Be careful to not touch the motherboard with the soldering iron, you can damage the circuits.
    • After you have melted and removed the solder, flip the mother board around and identify the connecting points of the power port.
    • Use a black spudger to gently separate the power port from the motherboard
    Ask FixBot
2 other people completed this guide.
Tyler Markiewicz
267 Reputation
1 Guide authored
USF Tampa, Team 11-1, Blackwell Fall 2016 Member of USF Tampa, Team 11-1, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G1
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 30
All Time: 1,298
