Linksys EA6900 USB Ports Replacement
  1. Linksys EA6900 USB Ports Replacement, Linksys EA6900 Disassembly: step 1, image 1 of 3 Linksys EA6900 USB Ports Replacement, Linksys EA6900 Disassembly: step 1, image 2 of 3 Linksys EA6900 USB Ports Replacement, Linksys EA6900 Disassembly: step 1, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the antennas by unscrewing them from the base.
    • Flip over the device and locate the four rubber feet on the bottom.
    • Remove the rubber feet with tweezers
    Ask FixBot
  2. Linksys EA6900 USB Ports Replacement: step 2, image 1 of 1
    • Remove the 0.4cm head screws from each slot with the #1 Phillips head Screwdriver.
    Ask FixBot
  3. Linksys EA6900 USB Ports Replacement: step 3, image 1 of 1
    • Use a blue plastic opening tool to remove the top cover.
    • Move the blue plastic opening tool gently underneath the top cover from side to side.
    Ask FixBot
  4. Linksys EA6900 USB Ports Replacement: step 4, image 1 of 3 Linksys EA6900 USB Ports Replacement: step 4, image 2 of 3 Linksys EA6900 USB Ports Replacement: step 4, image 3 of 3
    • Gently lift the motherboard and remove it from the case
    • Put the motherboard over a (preferably white) surface.
    Ask FixBot
  5. Linksys EA6900 USB Ports Replacement, USB Ports: step 5, image 1 of 3 Linksys EA6900 USB Ports Replacement, USB Ports: step 5, image 2 of 3 Linksys EA6900 USB Ports Replacement, USB Ports: step 5, image 3 of 3
    • Locate the USB ports on both sides of the router motherboard. There are six points on the reverse side where the USB ports are soldered onto.
    • Apply the soldering iron carefully to the six points to melt to solder. Touching the motherboard with the solder can damage the circuits.
    • Be careful with using the soldering iron, it is hot!
    • After the solder has melted and been removed, gently pry the USB port with a black spudger to separate it from the motherboard.
    • Confirm that all of the old solder has been removed after the USB port is detached from the motherboard.
    Ask FixBot
2 other people completed this guide.
Matt Tryon
152 Reputation
1 Guide authored
USF Tampa, Team 11-1, Blackwell Fall 2016 Member of USF Tampa, Team 11-1, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G1
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 30
All Time: 728
