Linksys EA6900 Antenna Replacement
    1. Linksys EA6900 Antenna Replacement, Linksys EA6900 Disassembly: step 1, image 1 of 3 Linksys EA6900 Antenna Replacement, Linksys EA6900 Disassembly: step 1, image 2 of 3 Linksys EA6900 Antenna Replacement, Linksys EA6900 Disassembly: step 1, image 3 of 3
      Tool used on this step:
      Buy
      • Remove the antennas by unscrewing them from the base.
      • Flip over the device and locate the four rubber feet on the bottom.
      • Remove the rubber feet with tweezers
      Ask FixBot
    2. Linksys EA6900 Antenna Replacement: step 2, image 1 of 1
      • Remove the 0.4cm head screws from each slot with the #1 Phillips head Screwdriver.
      Ask FixBot
    3. Linksys EA6900 Antenna Replacement: step 3, image 1 of 1
      • Use a blue plastic opening tool to remove the top cover.
      • Move the blue plastic opening tool gently underneath the top cover from side to side.
      Ask FixBot
    4. Linksys EA6900 Antenna Replacement: step 4, image 1 of 3 Linksys EA6900 Antenna Replacement: step 4, image 2 of 3 Linksys EA6900 Antenna Replacement: step 4, image 3 of 3
      • Gently lift the motherboard and remove it from the case
      • Put the motherboard over a (preferably white) surface.
      Ask FixBot
    1. Linksys EA6900 Antenna Replacement, Antenna: step 5, image 1 of 2 Linksys EA6900 Antenna Replacement, Antenna: step 5, image 2 of 2
      • Detach the wires from the motherboard.
      • Flip the motherboard and repeat the process.
      Ask FixBot
    2. Linksys EA6900 Antenna Replacement: step 6, image 1 of 2 Linksys EA6900 Antenna Replacement: step 6, image 2 of 2
      • Locate the four solder points on each port and melt them using a soldering iron.
      • Wait between five and seven minutes for the ports to cool down.
      • Remove each port using a nylon spudger
      Ask FixBot
5 other people completed this guide.
Denis
611 Reputation
3 Guides authored
USF Tampa, Team 11-1, Blackwell Fall 2016 Member of USF Tampa, Team 11-1, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G1
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 69
All Time: 2,957
