ThinkPad will not turn on
The ThinkPad will not boot.
Broken power adapter
To check if your power adapter is broken, plug it into your ThinkPad and look for a charging indication light. If the light does not illuminate, the power adapter may be broken. If you are still unsure, remove the battery and plug the power supply into the ThinkPad. If the ThinkPad still does not respond, replace your power adapter.
Dead battery
If your battery cannot hold a charge, your ThinkPad will work with a power adapter but will not work when unplugged. If this is the case, see if this is the case. If so, remove the battery and order a replacement.
Bad RAM
If the computer boots up but crashes while loading Windows XP, your RAM may be bad. Ensure your RAM is seated correctly into the ThinkPad. If the problem persists, run a memory test such as MemTest. If the test finds any issues, you may need to replace the RAM.
Corrupted or dying hard drive
This issue may be difficult to diagnose because of the varying symptoms. After years of use, many hard drives begin to perform worse, break down, or completely fail. Sometimes you can boot your ThinkPad on and it will crash shortly afterwards, and sometimes your ThinkPad will not boot at all. To best diagnose this issue, find a computer technician to help you out. If the hard drive is the issue, you may need to replace the hard drive
Screen is not responding
Your ThinkPad's screen is frozen, blank, or visibly damaged.
Frozen screen
Try turning your computer off and on again. If the problem persists, ensure your video and graphics drivers are up-to-date, or if they were recently updated, try to uninstall these updates (this may seem counter-intuitive, but if it worked before a new update, the update may not be necessary).
Physically broken screen
If your screen is cracked or is displaying a white or line-filled screen with a shatter pattern (for example, something like this), your screen has been physically damaged and you will need to replace the screen.
Keyboard is not responding
The computer boots, but the keyboard does not respond to any input.
Software issues
If you recently installed any alternate keyboards for typing in different languages, make sure you are selected on the default English keyboard layout. To do this, click Start and then Control Panel. If you are in Category View, click on "Switch to Classic View" in the top left corner of the window. Then click "Regional and Langauge Options," then the "Languages" tab. From here, change the input language to English. If the keyboard still does not register any input, it may be a hardware issue.
Hardware issues
Try tapping the Caps Lock key (located on the left of the keyboard) to check if the indication light lights up. If the light does not appear, and you have ruled out software as a possible issue, you may need to replace the keyboard.
Optical drive is not reading disks
''The optical drive is not reading any disks, making abnormal sounds, or not responding at all."
Unsupported format
There are many different formats for optical disks. The IBM ThinkPad T30 is capable of playing CDs and DVDs. This does not include HD-DVDs, Blue-ray DVDs, or 3D movies. Please make sure that you are using a supported optical disk with your computer.
Unreadable disk
Sometimes the optical drive cannot read the disk because the disk itself is unreadable. Clean away any smudges, dirt, or grime on the disk and try to play it again. If the disk is significantly scratched or damaged, then it may be too damaged to repair and may need to be replaced.
Broken optical drive
If you are unable to play a clean and supported disk with the optical drive, your optical drive may be broken. You may need to replace your optical drive.
Speakers are not turning on
No sound is coming from the ThinkPad's speakers.
If the speakers are not functioning the problem may be software-related. Make sure the drivers are properly installed and up-to-date. If that is not the case, you may need to replace your speakers.
Fan is not working properly
The ThinkPad's fan is very loud, abnormally quiet or not functioning, or the ThinkPad is dangerously hot to the touch. The ThinkPad may shut down automatically because it gets so hot.
Jammed fan
Accumulated dust or other debris may be jamming the fan. Use a can of compressed air to clean the holes and crevices of your ThinkPad. If this does not help, you may need to get disassemble your ThinkPad to clean the dust inside directly.
Broken fan
If cleaning out the fan doesn't fix the issue, it may be time to replace the fan assembly.
Author
with
Gordon Kuo
325 Reputation
0 Guides authored
5 Comments
I took someone's advice and froze my T30 ThinkPad battery and it charged fast and the laptop came on and worked great. The next morning it wouldn't power up. Checked battery voltage and it's fine. I have tried the removing battery and power supply and tapping the power button, but nothing happens. Battery is holding charge like it should. I need help please.
Tom Kidd - Reply Share
Can anyone help me out? Please!
When it powered up, it worked and stayed cool, had been using an outside fan to help keep it cool before. I am bewildered.
I can't get any sound from my thinkpad was working good but all of a suddend the sound shut off ? Help plz
Lee Calder - Reply Share
My T30 is dead. All four indicator LEDs are lit on start up but three go out again immediately. Only the rightmost one stays on. The fan is not spinning at all (I can see this by lifting up the keyboard while still connected). It is not particularly dusty.
I have previously replaced the fan, but I can't remember the symptoms that caused me to do this. I believe that the fan should be on all the time - is this correct?
Thanks for any response.
Andrew Sommerville - Reply Share
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 24
All Time: 5,987
