Up to 20% off select tools
IBM ThinkPad T30 Fan Assembly Replacement
Views: 5.9K
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
100
All Time:
5,920
Comments: 5
1 comment on steps, 4 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Moderate
Missing Steps
Oops! This guide is currently missing one or more important steps.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
Use this guide to replace your fan and heat sink assembly.
    1. IBM ThinkPad T30 Fan Assembly Replacement, Battery: step 1, image 1 of 3 IBM ThinkPad T30 Fan Assembly Replacement, Battery: step 1, image 2 of 3 IBM ThinkPad T30 Fan Assembly Replacement, Battery: step 1, image 3 of 3
      • Make sure the ThinkPad is off and the power supply is unplugged.
      • Flip the ThinkPad upside down with the bottom facing you.
      • Slide the latch to the right into the unlock position.
      • While holding the latch in the unlock position, lift the battery out with your other hand.
      Ask FixBot
    1. IBM ThinkPad T30 Fan Assembly Replacement, Keyboard: step 2, image 1 of 2 IBM ThinkPad T30 Fan Assembly Replacement, Keyboard: step 2, image 2 of 2
      • Begin by removing the two black 16 mm Phillips #0 screws. The screws can be identified by the two notches next to each screw. One (marked in red) is near the battery lock and the other (not pictured) is next to the Wi-Fi cover.
      • Push up the bottom of the keyboard by poking your finger through the hole to the right of the yellow bios battery. You will feel slight resistance.
      • Be sure to not lift the keyboard too far. It is still attached to the computer with a ribbon connector.
      Ask FixBot
    2. IBM ThinkPad T30 Fan Assembly Replacement: step 3, image 1 of 3 IBM ThinkPad T30 Fan Assembly Replacement: step 3, image 2 of 3 IBM ThinkPad T30 Fan Assembly Replacement: step 3, image 3 of 3
      • Lift the keyboard to expose the ribbon connector and lean it against the computer screen to keep the ribbon intact.
      • If the ribbon is broken, the keyboard is permanently unusable and needs to be replaced
      • Use the plastic opening tool to gently pry the connector up from the motherboard.
      • You can now safely remove the keyboard.
      Ask FixBot
    1. IBM ThinkPad T30 Fan Assembly Replacement, Fan Assembly: step 4, image 1 of 2 IBM ThinkPad T30 Fan Assembly Replacement, Fan Assembly: step 4, image 2 of 2
      • Remove the three 4 mm Phillips #0 screws securing the fan assembly.
      Ask FixBot
    2. IBM ThinkPad T30 Fan Assembly Replacement: step 5, image 1 of 2 IBM ThinkPad T30 Fan Assembly Replacement: step 5, image 2 of 2
      • Using the plastic opening tool, gently pry the heat sink assembly up.
      • Be sure to reapply thermal compound on the processor and heat sink when reassembling the device.
      • Be aware that there still is a wire attached to the fan that is connected to motherboard upon removal.
      Ask FixBot
    3. IBM ThinkPad T30 Fan Assembly Replacement: step 6, image 1 of 2 IBM ThinkPad T30 Fan Assembly Replacement: step 6, image 2 of 2
      • Using the plastic opening tool, gently lift the white connector out of its socket on the motherboard.
      • Before installing the new fan, remove all remnants of thermal compound from the top of the CPU. Warning—the stuff is hard to clean off clothing. Spread a small amount of fresh heat sink compound (DC-340 or equivalent) on the top of the CPU to form a thin coat. Be sure the mating fan heat sink is clean.
      • Follow iFixit's guide for [invalid guide link] for a detailed explanation.
      Ask FixBot
6 other people completed this guide.
Author
with
Alex Kost
271 Reputation
5 Guides authored
Cal Poly, Team 3-20, Amido Fall 2012 Member of Cal Poly, Team 3-20, Amido Fall 2012
CPSU-AMIDO-F12S3G20
3 Members
96 Guides authored
4 Guide Comments
There are two screws for keyboard removal! Almost snapped the keyboard in half trying to pry it off
Dima - Reply Share
Excellent instructions and very easy to follow (thanks for the pictures, they helped a lot!) Took me more than half an hour, but then I was trying to shove the teeny tiny white fan connector thing into the slot backwards..(my bad).. there is not a lot of room to maneuver in there. My ancient computer is working again and that makes me very happy, so thanks!
ML Hinrich - Reply Share
Really excellent instructions. Thank You for Your help!! Rolf Frey, Lucerne, Switzerland
Rolf Frey - Reply Share
อยากได้พัดลมมีขายใหมThinkPad T30
Paradon Jitrakan - Reply Share
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 100
All Time: 5,920
