IBM ThinkPad T30 Hard Drive Replacement
Views: 21K
View statistics:
Past 24 Hours:
4
Past 7 Days:
29
Past 30 Days:
137
All Time:
21,037
Comments: 1
1 guide comment.
Go to guide comments
Completed: 11
11 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
In this guide, you will learn how to remove and replace a hard drive for an IBM ThinkPad T30 laptop. The laptop comes with an IDE / PATA Hard disk drive that is either 20/40/60GB and is easy to remove only using a few tools
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. IBM ThinkPad T30 Hard Drive Replacement, Battery: step 1, image 1 of 3 IBM ThinkPad T30 Hard Drive Replacement, Battery: step 1, image 2 of 3 IBM ThinkPad T30 Hard Drive Replacement, Battery: step 1, image 3 of 3
      • Make sure the ThinkPad is off and the power supply is unplugged.
      • Flip the ThinkPad upside down with the bottom facing you.
      • Slide the latch to the right into the unlock position.
      • While holding the latch in the unlock position, lift the battery out with your other hand.
      Ask FixBot
    1. IBM ThinkPad T30 Hard Drive Replacement, Hard Drive: step 2, image 1 of 1
      • Flip to the back of the Thinkpad.
      • Remove the single 11 mm screw using the Phillips #0 screwdriver.
      Ask FixBot
    2. IBM ThinkPad T30 Hard Drive Replacement: step 3, image 1 of 3 IBM ThinkPad T30 Hard Drive Replacement: step 3, image 2 of 3 IBM ThinkPad T30 Hard Drive Replacement: step 3, image 3 of 3
      • Flip the Thinkpad on its side to get a better view of the hard drive.
      • Push on the lower edge of the hard drive cover to detach the hard drive from the Thinkpad.
      • Once you have detached the hard drive from the Thinkpad, slide the hard drive out of the device.
      Ask FixBot
    3. IBM ThinkPad T30 Hard Drive Replacement: step 4, image 1 of 2 IBM ThinkPad T30 Hard Drive Replacement: step 4, image 2 of 2
      • Using the plastic tool, remove the black plastic cover from the main body of the hard drive.
      • Place the plastic tool at the ends of the plastic cover to detach it from the hard drive.
      • Once the black plastic has been detached, the plastic will then slide off the body of the hard drive.
      Ask FixBot
    4. IBM ThinkPad T30 Hard Drive Replacement: step 5, image 1 of 2 IBM ThinkPad T30 Hard Drive Replacement: step 5, image 2 of 2
      • Remove the four 2.8 mm screws from the mounting bracket using a Phillips #0 screwdriver.
      • Pull the mounting bracket off of the hard drive.
      • It may be easier to remove the mounting bracket by rotating it off of the hard drive as if it is on a hinge.
      Ask FixBot
To reassemble your device with a new hard drive, follow these instructions in reverse order with a new hard drive replacing the old one.
11 other people completed this guide.
Allie Knauer
90 Reputation
3 Guides authored
Cal Poly, Team 3-20, Amido Fall 2012 Member of Cal Poly, Team 3-20, Amido Fall 2012
CPSU-AMIDO-F12S3G20
3 Members
96 Guides authored
1 Guide Comment
good description and photos..thanks :]
David - Reply Share
Past 24 Hours: 4
Past 7 Days: 29
Past 30 Days: 137
All Time: 21,037
