Up to 20% off select tools
IBM ThinkPad T30 RAM Replacement
Views: 4.4K
View statistics:
Past 24 Hours:
Past 7 Days:
15
Past 30 Days:
91
All Time:
4,385
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the RAM in your IBM ThinkPad T30
    1. IBM ThinkPad T30 RAM Replacement, Battery: step 1, image 1 of 3 IBM ThinkPad T30 RAM Replacement, Battery: step 1, image 2 of 3 IBM ThinkPad T30 RAM Replacement, Battery: step 1, image 3 of 3
      • Make sure the ThinkPad is off and the power supply is unplugged.
      • Flip the ThinkPad upside down with the bottom facing you.
      • Slide the latch to the right into the unlock position.
      • While holding the latch in the unlock position, lift the battery out with your other hand.
      Ask FixBot
    1. IBM ThinkPad T30 RAM Replacement, RAM: step 2, image 1 of 2 IBM ThinkPad T30 RAM Replacement, RAM: step 2, image 2 of 2
      • Remove the 4 mm Phillips #0 screw located on the panel on the bottom right of the ThinkPad.
      • Lift up the cover and set it aside.
      Ask FixBot
    2. IBM ThinkPad T30 RAM Replacement: step 3, image 1 of 2 IBM ThinkPad T30 RAM Replacement: step 3, image 2 of 2
      • Locate the four white tabs. There are two sets of white tabs, the top two holding the first RAM stick and the bottom holding the second RAM stick.
      • Removing one set at a time, press down on the white tabs at the same time. The RAM stick will pop out of place.
      Ask FixBot
    3. IBM ThinkPad T30 RAM Replacement: step 4, image 1 of 2 IBM ThinkPad T30 RAM Replacement: step 4, image 2 of 2
      • Lift out the two RAM sticks.
      Ask FixBot
Author
with
Allie Knauer
90 Reputation
3 Guides authored
Cal Poly, Team 3-20, Amido Fall 2012 Member of Cal Poly, Team 3-20, Amido Fall 2012
CPSU-AMIDO-F12S3G20
3 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 91
All Time: 4,385
