Up to 20% off select tools
IBM ThinkPad T30 Battery Replacement
Views: 4.8K
View statistics:
Past 24 Hours:
8
Past 7 Days:
26
Past 30 Days:
122
All Time:
4,830
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
Use this guide to replace the battery for your IBM ThinkPad T30. Battery replacement may solve issues related to performance, battery life, charging times, and other hardware functions. No special skills or tools are required for this short replacement. Before beginning the guide, ensure the device is off and power supply is unplugged.
    1. IBM ThinkPad T30 Battery Replacement, Battery: step 1, image 1 of 3 IBM ThinkPad T30 Battery Replacement, Battery: step 1, image 2 of 3 IBM ThinkPad T30 Battery Replacement, Battery: step 1, image 3 of 3
      • Make sure the ThinkPad is off and the power supply is unplugged.
      • Flip the ThinkPad upside down with the bottom facing you.
      • Slide the latch to the right into the unlock position.
      • While holding the latch in the unlock position, lift the battery out with your other hand.
      Ask FixBot
2 other people completed this guide.
Author
with
Allie Knauer
90 Reputation
3 Guides authored
Cal Poly, Team 3-20, Amido Fall 2012 Member of Cal Poly, Team 3-20, Amido Fall 2012
CPSU-AMIDO-F12S3G20
3 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 26
Past 30 Days: 122
All Time: 4,830
