Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Hoverboard Has Flashing Red Light
The hoverboard will not operate despite charge and other functions working
Motor Circuits Are Causing Motherboard Malfunctions
When this occurs, a red light will flash 4 times. This means that internal circuitry of the motor is causing the wheel on the motherboard side to malfunction. This requires a full replacement of the motherboard side motor. Please view Hover-1 Liberty Gyroscope Sensor Boards Replacement.
Motor Circuits Are Causing Motor Malfunctions
When this occurs, a red light will flash 5 times. This means that internal circuitry of the motor is causing the wheel on the battery side to malfunction. This requires a full replacement of the battery side motor. Please view Hover-1 Liberty Wheel Motor Replacement.
Hoverboard Will Not Balance
The hoverboard does not remain upright when trying to mount.
Hoverboard Needs to Recalibrate
One common fix to an unbalanced hoverboard is to recalibrate the system. in order do this, stand the hoverboard flat on both wheels and hold the power button down until the LED lights start to flash. Wait two to five seconds and turn hover board off. Power on normally.
Hoverboard Has Loose Wires
The wires connecting the motor and motherboard may be loose. To check you will need to open the device and check the connections. Please view Hover-1 Liberty Bottom Cover Replacement.
Hoverboard Has a Broken Gyroscope
If recalibration does not work, then the gyroscopes in your hoverboard may be faulty. The red indicator light on the top of the hoverboard will flash 7 times to denote the gyroscope on the battery side is the issue or 8 times for the gyroscope on the motherboard side. Please view Hover-1 Liberty Gyroscope Sensor Boards Replacement.
Hoverboard Has a Faulty Motherboard
The last component that may be broken is the hoverboard's motherboard. A red indicator light on the top of the hoverboard will flash once to denote this error. Please view Hover-1 Liberty Gyroscope Sensor Boards Replacement.
Hoverboard Will Not Drive
The hoverboard wheels will not spin.
The hoverboard may have wires that are not firmly connected to one another. Please view Hover-1 Liberty Bottom Cover Replacement to open the device and check the connections.
If the connections are all secure, then the problem may be the motherboard. The red indicator light on the top of the hoverboard will flash once to denote this error. Please view Hover-1 Liberty Gyroscope Sensor Boards Replacement.
Hoverboard Has Something Blocking Magnets in the Wheels
If connections are all secure, then make sure to check the wheel interior for debris. To do this you will need to remove the magnetic turbine from the wheel. The red indicator light on the top of the hoverboard will flash 5 times to denote the wheel on the battery side is the issue or 4 times for the wheel on the mainboard side. Please view Hover-1 Liberty Wheel Motor Replacement.
Hoverboard Will Not Power On
The hoverboard shows no signs of powering up when the power button is pressed.
Hoverboard Not Charged
Make sure the board is charged. If the board has been charging for a long time but still wont power on. There may be an issue with the charger, or charging circuit. Please view the Hoverboard Will Not Charge or Hold a Charge section.
Loose Power Button Cable
Check that the power button cable is completely connected to motherboard. Remove the cover. Please view Hover-1 Liberty Bottom Cover Replacement. Then check that the wires connecting the power button are in good condition and connected to the motherboard.
Loose Battery Connection
With the external cover removed, check the the two large wires connecting the battery to the motherboard are in good condition and don’t have debris inside the connector.
Faulty Motherboard
If the hoverboard will still not power on, and the condition of the power connections is good. The motherboard may not be supplying power to the hoverboard. A red indicator light on the top of the hoverboard will flash once to denote this error. Please view Hover-1 Liberty Gyroscope Sensor Boards Replacement.
Hoverboard Will Not Hold a Charge
The hoverboard shows no sign of charging
Battery level codes:
GREEN: over 20%
YELLOW: under 20%
RED: under 10%
Faulty Charger
Plug the charger into the wall and disconnect the charger from the board. The charger light should be bright green. If there is no light, make sure the charger adapter is completely inserted into the charger brick. If the light stays off, consider purchasing a replacement charger.
Faulty Battery
If the light on charger is off when plugged into board, this could be a faulty battery or motherboard. A red indicator light on the top of the hoverboard will flash six times to denote this error. View Hover-1 Liberty Battery Replacement.
Faulty Motherboard
Light Stays green while board is plugged in, but the battery is not charged. A red indicator light on the top of the hoverboard will flash once to denote this error. View Hover-1 Liberty Gyroscope Sensor Boards Replacement.
To further troubleshoot your device, please visit the Hover-1 Troubleshooting and Support page.
Author
with
Patrick Bacon
438 Reputation
2 Guides authored
Cal Poly, Team S13-G2, White Fall 2018 Member of Cal Poly, Team S13-G2, White Fall 2018
CPSU-WHITE-F18S13G2
3 Members
48 Guides authored
48 Comments
My daughters hover-1 will not move. Just got it for Christmas. Was working good the just stopped one side the lights stays on and smells hot. Will not power down. Please help
LaChele Wolfenbarger - Reply Share
Same problem with my daughters as well. If you find a fix, please post.
Brian - Reply Share
I found a site where it references light stats on on one side and does not power down. It stated that that side with the light on has a bad gyroscope that controls that side. It said it can’t be fixed and needs replaced. In my case, I’m returning tomorrow for another one and try our luck with that.
Brian - Reply Share
Were any of you able to fix this problem? My daughters is having the same problem
Renee P - Reply Share
Mine just lets me ride it for a second then beeps red even if I charge for 6 hrs straight. anyone can help?
Anna Black - Reply Share
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 67
All Time: 54,890
