Hover-1 Liberty Battery Replacement
    1. Hover-1 Liberty Battery Replacement, Bottom Cover: step 1, image 1 of 2 Hover-1 Liberty Battery Replacement, Bottom Cover: step 1, image 2 of 2
      • Flip the hoverboard over so the labels are facing upwards.
      • Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
      Ask FixBot
    2. Hover-1 Liberty Battery Replacement: step 2, image 1 of 2 Hover-1 Liberty Battery Replacement: step 2, image 2 of 2
      • Remove the bottom cover by lifting it away from the hoverboard.
      • The cover on the side without the battery has two wires connecting the power button and charging port.
      Ask FixBot
    3. Hover-1 Liberty Battery Replacement: step 3, image 1 of 3 Hover-1 Liberty Battery Replacement: step 3, image 2 of 3 Hover-1 Liberty Battery Replacement: step 3, image 3 of 3
      • Remove one connector from the non-battery side circuit board.
      • Remove the next connector from the non-battery side circuit board.
      • To remove the connectors, pinch the plug and pull away from the circuit board.
      Ask FixBot
    1. Hover-1 Liberty Battery Replacement, Battery: step 4, image 1 of 2 Hover-1 Liberty Battery Replacement, Battery: step 4, image 2 of 2
      • Disconnect the large red and black wire from the battery by pulling apart the connector.
      Ask FixBot
    2. Hover-1 Liberty Battery Replacement: step 5, image 1 of 2 Hover-1 Liberty Battery Replacement: step 5, image 2 of 2
      • Remove the four 15mm Phillips #1 screws from the bracket holding the battery in place.
      Ask FixBot
    3. Hover-1 Liberty Battery Replacement: step 6, image 1 of 2 Hover-1 Liberty Battery Replacement: step 6, image 2 of 2
      • Remove the bracket by pulling it upwards, away from the hoverboard.
      • You will need to move some wires aside to remove the bracket successfully.
      Ask FixBot
    4. Hover-1 Liberty Battery Replacement: step 7, image 1 of 3 Hover-1 Liberty Battery Replacement: step 7, image 2 of 3 Hover-1 Liberty Battery Replacement: step 7, image 3 of 3
      • Remove the battery by grasping the battery and hoverboard firmly and pulling apart.
      • The battery is held in place by adhesive. So, some force is required to remove it.
      Ask FixBot
Patrick Bacon
438 Reputation
2 Guides authored
Cal Poly, Team S13-G2, White Fall 2018 Member of Cal Poly, Team S13-G2, White Fall 2018
CPSU-WHITE-F18S13G2
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 60
All Time: 3,365
