Hover-1 Liberty Wheel Motor Replacement
  1. Hover-1 Liberty Wheel Motor Replacement, Bottom Cover: step 1, image 1 of 2 Hover-1 Liberty Wheel Motor Replacement, Bottom Cover: step 1, image 2 of 2
    • Flip the hoverboard over so the labels are facing upwards.
    • Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
    Ask FixBot
  2. Hover-1 Liberty Wheel Motor Replacement: step 2, image 1 of 2 Hover-1 Liberty Wheel Motor Replacement: step 2, image 2 of 2
    • Remove the bottom cover by lifting it away from the hoverboard.
    • The cover on the side without the battery has two wires connecting the power button and charging port.
    Ask FixBot
  3. Hover-1 Liberty Wheel Motor Replacement: step 3, image 1 of 3 Hover-1 Liberty Wheel Motor Replacement: step 3, image 2 of 3 Hover-1 Liberty Wheel Motor Replacement: step 3, image 3 of 3
    • Remove one connector from the non-battery side circuit board.
    • Remove the next connector from the non-battery side circuit board.
    • To remove the connectors, pinch the plug and pull away from the circuit board.
    Ask FixBot
  4. Hover-1 Liberty Wheel Motor Replacement, Gyroscope Sensor Boards: step 4, image 1 of 1
    • Place the hoverboard so the sensor boards face you.
    Ask FixBot
  5. Hover-1 Liberty Wheel Motor Replacement: step 5, image 1 of 2 Hover-1 Liberty Wheel Motor Replacement: step 5, image 2 of 2
    • Remove battery connector by pulling it apart.
    • Slide the rubber sheaths away from the connector on the blue, green, and yellow wires.
    • Disconnect the colored wires by pulling them apart.
    • The large colored wires connecting the sensor boards to the wheels need to match for the motor to operate correctly.
    Ask FixBot
  6. Hover-1 Liberty Wheel Motor Replacement: step 6, image 1 of 2 Hover-1 Liberty Wheel Motor Replacement: step 6, image 2 of 2
    • Remove the white cable from the sensor boards by disconnecting the cable on each side of the hoverboard.
    • To release the cable connector, squeeze the sides while pulling it away from the sensor board.
    Ask FixBot
  7. Hover-1 Liberty Wheel Motor Replacement: step 7, image 1 of 2 Hover-1 Liberty Wheel Motor Replacement: step 7, image 2 of 2
    • Remove the four 10mm screws with a Phillips #1 screwdriver.
    Ask FixBot
  8. Hover-1 Liberty Wheel Motor Replacement: step 8, image 1 of 2 Hover-1 Liberty Wheel Motor Replacement: step 8, image 2 of 2
    • Remove the sensor board by lifting it away from the hoverboard.
    • Repeat steps 4-8 to remove the sensor board from the other side.
    Ask FixBot
  9. Hover-1 Liberty Wheel Motor Replacement, Wheel Motor: step 9, image 1 of 2 Hover-1 Liberty Wheel Motor Replacement, Wheel Motor: step 9, image 2 of 2
    • Place the hoverboard so the four 36mm Allen bolts are pointing up.
    • Remove the four 36mm Allen bolts on each side using a 5mm Allen Wrench.
    • The four Allen bolts have lock washers.
    Ask FixBot
  10. Hover-1 Liberty Wheel Motor Replacement: step 10, image 1 of 2 Hover-1 Liberty Wheel Motor Replacement: step 10, image 2 of 2
    • Lift the metal retaining plate away from the motor shaft.
    Ask FixBot
  11. Hover-1 Liberty Wheel Motor Replacement: step 11, image 1 of 2 Hover-1 Liberty Wheel Motor Replacement: step 11, image 2 of 2
    • Lift motor assembly away from hoverboard.
    • There is a flat section on the motor shaft that needs to point up, towards metal plate.
    • The motor assembly should be flush with side of hoverboard.
    Ask FixBot
3 other people completed this guide.
Eduardo Miranda
355 Reputation
2 Guides authored
Cal Poly, Team S13-G2, White Fall 2018 Member of Cal Poly, Team S13-G2, White Fall 2018
CPSU-WHITE-F18S13G2
3 Members
4 Guides authored
2 Guide Comments
My bracket the wheel attaches to hoverboard is broke can that portion of board be replaced? Where can I buy it if so?
Adam Vernengo - Reply Share
Can I buy a replacement battery side motor for hover1 drive hoverboard. If so, where? Can’t seem to find it on internet
luke-1115@hotmail.com - Reply Share
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 31
All Time: 5,789
