Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Camera won't turn on
No matter what you do, you can't get your camera to turn on.
Low Charge
Before you get a new camera, try plugging it in to charge it.
Dead Battery
If it still doesn't turn on, the battery could be dead, in which case you should replace it! Click here for our guide on how to replace the battery!
Circuit Board Issues
It could be that your circuit board is broken or isn't connected properly, in which case you will need to go in a check it out to see if you need to replace it or just fix it. Here is a guide on how to replace it.
Camera won't charge
You've plugged it in, but the camera doesn't show any signs of charging
Bad Charger
Your charger may have gone bad or one of the connectors may be damaged. Try using/buying a new charger. You can find one here.
Dead Battery
If it still doesn't charge, the battery could be dead so you need to replace it! Click here for our guide on how to replace the battery!
Bad Charging Port
It could be that your camera's charging port is broken or dysfunctional. Here is a guide on how to replace the port!
The camera will not turn on when a SD card is inserted
You've inserted an SD card and now you're camera won't turn on
Incompatible SD Card
Make sure your SD card is compatible with the GoPro camera. You should be using a microSD card that is up to 32 GB. Here is a link for recommended SD cards
Faulty SD Card
SD cards can sometimes be faulty, preventing the camera to turn on, in which case, you need a new SD card.
The SD card sticks out of the camera, or doesn't lock into place
For some reason, the SD card isn't going in all the way
Not Pushed in Far Enough
Maybe you’re just not pushing it in far enough. Use your fingernail to really get it in there, until it clicks into place. But do be careful, you don't want to break anything.
Blocked Slot
If it still won’t go in, there may be something blocking it, in which case, you need to clean out the card slot, either using our tools here, or by using just a little compressed air specifically for cleaning electronics.
The camera isn't reading the SD card
You're taking photos but the photos aren't going on your SD card
Bad SD Port
It could be that the camera just can't read the SD card because the SD port is faulty. Here is a guide on how to replace it!
It could be that your circuit board is broken or isn't connected properly, in which case you will need to go in a check it out to see if you need to replace it or just fix it. Here is how!
The batteries do not last very long
Every time you go on an adventure, your fun is cut short because your camera dies, no matter how much you charged it
Old Battery
The battery might be old and may not hold the charge for as long, in which case you would need to replace it! Click here for our guide on how to replace the battery!
The camera is not responding
No matter what buttons you push, your camera isn't responding
Reset
Hold down the Power/Mode button for 8 seconds to reset the camera. It saves all of your content and settings and powers off your camera
Your pictures turn out disfigured
Your pictures are perfect except for maybe one section on every one of them
Dirty Lens
It could be that some particles or water vapor somehow got inside the case, and mucked up the lens. All you have to do is go in and clean it! You can clean it safely with this!
Scratched Lens
The lens could be scratched, in which case you need to replace it! Click here to find out how!
Your LCD screen doesn't show anything or is cracked
You can't tell what setting the camera is in because the LCD screen is dysfunctional
Disconnected LCD Screen
It could be that your LCD Screen was just disconnected so before you drop some cash to replace it, you can make sure that the connector is still in place.
Broken LCD Screen
The LCD screen could be cracked or completely broken, in which case you can replace it. Click here to find out how! Parts can be found here. Note: The Hero 3 LCD screen is the same as the Hero
Author
with
River Drake
1,065 Reputation
5 Guides authored
Cal Poly, Team 12-2, Lancaster Spring 2015 Member of Cal Poly, Team 12-2, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G2
4 Members
72 Guides authored
6 Comments
Thank you! Sorted out my new camera whilst on holiday in tropical Maldives. Excellent site
tracey - Reply Share
I never put a lock on my GoPro , how can I take it off , I can not do anything but take pics and videos . I am not able to see my photos
Jahaida Pesquera - Reply Share
My GoPro was working fine before I put in the micro SD card, after that it said SD card error and the screen turned black and is unresponsive when I turn on the GoPro. I cannot access the screen at all. This is probably because I tried using a micro SD card that is not recommended by GoPro. I would like to know how to reset the camera, or get the screen to come on again.
Attila Vastag - Reply Share
My Hero 9 front display is not working. But red light is showing and sometimes little light comes and again goes off. Please Help.
JAAN KEMPRAI - Reply Share
When my gopro hero is charging and when it says full battery I unplug it and after that it turns off. Can you please help with that?
Tavin Medina - Reply Share
Past 24 Hours: 0
Past 7 Days: 21
Past 30 Days: 134
All Time: 33,124
