Up to 20% off select tools
GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement
Views: 6.1K
View statistics:
Past 24 Hours:
5
Past 7 Days:
29
Past 30 Days:
121
All Time:
6,111
Comments: 4
4 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Better Introduction
Improve this guide by completing or revising its introduction.
Parts
    1. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement, Casing: step 1, image 1 of 1
      • Power off your GoPro before beginning disassembly.
      • Unclip the black latch to the camera case and open the case.
      Ask FixBot
    2. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: step 2, image 1 of 1
      • Gently pry the back open by inserting a metal spudger between the case and back panel.
      Ask FixBot
    3. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: step 3, image 1 of 1
      • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
      Ask FixBot
    4. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: step 4, image 1 of 1
      • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
      Ask FixBot
    5. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: step 5, image 1 of 1
      • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
      • Make sure to keep track of these screws as they are very small.
      Ask FixBot
    6. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: step 6, image 1 of 1
      • Carefully remove the motherboard and white plastic piece from the case.
      Ask FixBot
    1. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement, Micro USB/MicroSD Card Daughter Board: step 7, image 1 of 2 GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement, Micro USB/MicroSD Card Daughter Board: step 7, image 2 of 2
      • Remove the larger ribbon cable from the daughter board by lifting the black latch and pulling the ribbon cable gently from the socket.
      • Disconnect the smaller ribbon cable leading from the white plastic piece by simply pulling it from the socket.
      Ask FixBot
    2. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: step 8, image 1 of 1
      • Remove the two screws located on each side of the board with a Phillips screwdriver.
      • The screws go through an L metal bracket that will come off with the screws.
      Ask FixBot
    3. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: step 9, image 1 of 1
      • Separate the daughter board from the white plastic piece.
      Ask FixBot
5 other people completed this guide.
Author
with
River Drake
1,065 Reputation
5 Guides authored
Cal Poly, Team 12-2, Lancaster Spring 2015 Member of Cal Poly, Team 12-2, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G2
4 Members
72 Guides authored
4 Guide Comments
Wo kann ich ein daughterboard kaufen habt ihr da was für mich?
Lukas Blohm - Reply Share
bravo! è scritto molto bene ed è stato utile. ma dove trovo il ricambio? non ci riesco!!!
michele - Reply Share
Terrific guide. Does anyone know where to buy the “daughter board”?
fedebossert - Reply Share
fedebossert - 05/27/20
<a href="https://www.w3schools.com/">Visit W3Schools.com!</a>
pavan kalyan - Reply Share
Past 24 Hours: 5
Past 7 Days: 29
Past 30 Days: 121
All Time: 6,111
