Up to 20% off select tools
GoPro Hero Motherboard Replacement
Views: 13K
View statistics:
Past 24 Hours:
7
Past 7 Days:
35
Past 30 Days:
148
All Time:
12,559
Comments: 2
2 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Better Introduction
Improve this guide by completing or revising its introduction.
Parts
Tools
    1. GoPro Hero Motherboard Replacement, Casing: step 1, image 1 of 1
      • Power off your GoPro before beginning disassembly.
      • Unclip the black latch to the camera case and open the case.
      Ask FixBot
    2. GoPro Hero Motherboard Replacement: step 2, image 1 of 1
      • Gently pry the back open by inserting a metal spudger between the case and back panel.
      Ask FixBot
    3. GoPro Hero Motherboard Replacement: step 3, image 1 of 1
      • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
      Ask FixBot
    4. GoPro Hero Motherboard Replacement: step 4, image 1 of 1
      • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
      Ask FixBot
    5. GoPro Hero Motherboard Replacement: step 5, image 1 of 1
      • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
      • Make sure to keep track of these screws as they are very small.
      Ask FixBot
    6. GoPro Hero Motherboard Replacement: step 6, image 1 of 1
      • Carefully remove the motherboard and white plastic piece from the case.
      Ask FixBot
    1. GoPro Hero Motherboard Replacement, Motherboard: step 7, image 1 of 2 GoPro Hero Motherboard Replacement, Motherboard: step 7, image 2 of 2
      • Remove the larger ribbon cable from the daughter board by lifting the black latch and pulling the ribbon cable gently from the socket.
      • Disconnect the smaller ribbon cable leading from the white plastic piece by simply pulling it from the socket.
      Ask FixBot
    2. GoPro Hero Motherboard Replacement: step 8, image 1 of 2 GoPro Hero Motherboard Replacement: step 8, image 2 of 2
      • Separate the white plastic piece from the motherboard.
      Ask FixBot
4 other people completed this guide.
Author
with
Zoe Tuggle
179 Reputation
1 Guide authored
Cal Poly, Team 12-2, Lancaster Spring 2015 Member of Cal Poly, Team 12-2, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G2
4 Members
72 Guides authored
2 Guide Comments
So after doing all theses steps did it resolve the problem
Anita - Reply Share
Thanks so much I really needed this guide.
Thanks, Sam
Sam Liam Matthews - Reply Share
Past 24 Hours: 7
Past 7 Days: 35
Past 30 Days: 148
All Time: 12,559
