Up to 20% off select tools
GoPro Hero Lens Replacement
Views: 15K
View statistics:
Past 24 Hours:
4
Past 7 Days:
33
Past 30 Days:
158
All Time:
14,759
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
This guide will entail taking all of the GoPro's components out, as the lens is at the bottom. Because the GoPro Hero is not very repairable, this guide is not for the faint of heart. However, if you follow the steps correctly, you should be able to replace the lens, instead of buying a new camera.
    1. GoPro Hero Lens Replacement, Casing: step 1, image 1 of 1
      • Power off your GoPro before beginning disassembly.
      • Unclip the black latch to the camera case and open the case.
      Ask FixBot
    2. GoPro Hero Lens Replacement: step 2, image 1 of 1
      • Gently pry the back open by inserting a metal spudger between the case and back panel.
      Ask FixBot
    3. GoPro Hero Lens Replacement: step 3, image 1 of 1
      • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
      Ask FixBot
    4. GoPro Hero Lens Replacement: step 4, image 1 of 1
      • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
      Ask FixBot
    5. GoPro Hero Lens Replacement: step 5, image 1 of 1
      • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
      • Make sure to keep track of these screws as they are very small.
      Ask FixBot
    6. GoPro Hero Lens Replacement: step 6, image 1 of 1
      • Carefully remove the motherboard and white plastic piece from the case.
      Ask FixBot
    1. GoPro Hero Lens Replacement, Lens: step 7, image 1 of 1
      • Remove the four screws from the lens.
      • These screws are smaller than the ones removed from the white plastic piece.
      Ask FixBot
    2. GoPro Hero Lens Replacement: step 8, image 1 of 1
      • Remove the lens from the case.
      Ask FixBot
To reassemble your device, follow the instructions in reverse order.
3 other people completed this guide.
Author
with
River Drake
1,065 Reputation
5 Guides authored
Cal Poly, Team 12-2, Lancaster Spring 2015 Member of Cal Poly, Team 12-2, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G2
4 Members
72 Guides authored
1 Guide Comment
I followed this list, but I think I knocked a component off of the motherboard while I was unscrewing it. I wasn’t planning on ever putting it back together, since I have a newer GoPro camera. Luckily, the lens and the cable connecting it didn’t get damaged. Is there maybe a way to connect the lens to the Raspberry Pi Zero?
Doggo Boi - Reply Share
Past 24 Hours: 4
Past 7 Days: 33
Past 30 Days: 158
All Time: 14,759
