Up to 20% off select tools
GoPro Hero LCD Screen Replacement
Views: 28K
View statistics:
Past 24 Hours:
10
Past 7 Days:
49
Past 30 Days:
232
All Time:
28,273
Comments: 4
1 comment on steps, 3 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Parts
Tools
Introduction
Go to step 1 ↓
If for some reason, your screen is dysfunctional, you can replace it. Since it is near the bottom of the camera, it is not easy to replace. Grab your screwdrivers and tweezers and let's go!
    1. GoPro Hero LCD Screen Replacement, Casing: step 1, image 1 of 1
      • Power off your GoPro before beginning disassembly.
      • Unclip the black latch to the camera case and open the case.
      Ask FixBot
    2. GoPro Hero LCD Screen Replacement: step 2, image 1 of 1
      • Gently pry the back open by inserting a metal spudger between the case and back panel.
      Ask FixBot
    3. GoPro Hero LCD Screen Replacement: step 3, image 1 of 1
      • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
      Ask FixBot
    4. GoPro Hero LCD Screen Replacement: step 4, image 1 of 1
      • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
      Ask FixBot
    5. GoPro Hero LCD Screen Replacement: step 5, image 1 of 1
      • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
      • Make sure to keep track of these screws as they are very small.
      Ask FixBot
    6. GoPro Hero LCD Screen Replacement: step 6, image 1 of 1
      • Carefully remove the motherboard and white plastic piece from the case.
      Ask FixBot
    1. GoPro Hero LCD Screen Replacement, LCD Screen: step 7, image 1 of 2 GoPro Hero LCD Screen Replacement, LCD Screen: step 7, image 2 of 2
      • Remove the larger ribbon cable from the daughter board by lifting the black latch and pulling the ribbon cable gently from the socket.
      • Disconnect the smaller ribbon cable leading from the white plastic piece by simply pulling it from the socket.
      Ask FixBot
    2. GoPro Hero LCD Screen Replacement: step 8, image 1 of 1
      • Separate the motherboard from the white piece of plastic.
      Ask FixBot
    3. GoPro Hero LCD Screen Replacement: step 9, image 1 of 1
      • Remove the ribbon cable from the motherboard by simply pulling the cable from the socket.
      Ask FixBot
    4. GoPro Hero LCD Screen Replacement: step 10, image 1 of 2 GoPro Hero LCD Screen Replacement: step 10, image 2 of 2
      • Separate the LCD screen from the motherboard.
      Ask FixBot
6 other people completed this guide.
Author
with
River Drake
1,065 Reputation
5 Guides authored
Cal Poly, Team 12-2, Lancaster Spring 2015 Member of Cal Poly, Team 12-2, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G2
4 Members
72 Guides authored
3 Guide Comments
Where do you buy the replacement lcd
Anthony Volatile - Reply Share
Gopro hero 7 white repair cost:
Screen: $45 - https://www.ebay.com.au/itm/183828969944
Side panel: $35 - https://www.herogear.com.au/genuine-repl...
Addisen KING - Reply Share
I can find the screen but is it compatible with the Hero+
Brian Casado - Reply Share
Past 24 Hours: 10
Past 7 Days: 49
Past 30 Days: 232
All Time: 28,273
