Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Device won't power on
When you press the power button, the camera won't turn on
Batteries are not seated properly
Remove the batteries and reinsert them. Then power up the camera in the event it was a temporary malfunction.
Dead or bad batteries
Before taking apart the camera, replace the batteries to ensure this is not the problem.
Camera powers on but screen does not display
In this case the screen may need to be replaced see our Screen Replacement Guide
Damaged battery door
The damage to the battery door of your devices' back plate is causing hand discomfort or poor battery connection.
Battery door won't latch
Check to see if there is debris obstructing the closing of the door, if there is clean it out gently with a toothpick.
The door is completely unusable
If the battery door is broken beyond repair you will want to consult our Battery Door Replacement Guide
The flash lid will not pop up
The button to release the flash lid did not fully open the lid
Make sure nothing is obstructing the flash lid
Check for debris or other miscellaneous gunk that could be preventing the lid from opening.
The lid is ajar and still won't open
Attempt to gently pry open the lid using an item that is small and thin that will not cause damage to the device. Be careful when doing this. try not to damage the device or injure yourself.
If the lid still won't spring open
Refer to our Flash Lid Spring Replacement Guide
Camera will not flash
While taking attempting to take a picture the flash does not go off
Make sure the flash is turned on
Check on the screen to see if the flash indicator icon is present. If the icon is not displayed, press the lightning bolt button on the right of the radial push button.
Replace the flash
This may be an indication that the flash if faulty and refer to our Flashbulb Replacement Guide
My camera buttons are not working
Pressing the record button on the camera does not record video
Ensure there isn't anything obstructing the buttons
Check for any debris obstructing the buttons being pressed down, if there is debris clean it out gently with a toothpick.
Replace the Button Panel
Refer to our Button Panel Replacement Guide
The speaker will not output any audio
"When watching my recording no audio is heard"
Ensure your device has enough power
"Replace the batteries to make sure the speaker has enough power"
Replace the speaker
Refer to our Speaker Replacement Guide
Colton Lancsarics
731 Reputation
6 Guides authored
USF Tampa, Team 3-2, Sullivan Spring 2016 Member of USF Tampa, Team 3-2, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G2
4 Members
72 Guides authored
8 Comments
My zoom is not working is there a fix for this
Hezikiah Pritchett - Reply Share
i have tried everything on here with no luck, this is not my first s8630 it’s my third, and they ALL have done the same thing, when I take batteries out for replacement on ALL three that i have owned, they will not power up for anything, I just tried new duracell batteries and no luck, can anyone help me?
DAVID B - Reply Share
Why would the camera shut off rt after I turn it on and if Powers up and j have put new batteries and still the same thing. I turn if on and if Powers up and shuts back off ?
itclint - Reply Share
im looking everywhere for this same problem. i have a finepix 8600 and it has the same issue. if you find a solution please let us know.
C B - Reply Share
My camera keeps saying memory card error
Linda herd - Reply Share
Past 24 Hours: 0
Past 7 Days: 16
Past 30 Days: 58
All Time: 3,009
