Fujifilm FinePix S8630 Flash Lid Spring Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
90
All Time:
816
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 45 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Fujifilm FinePix S8630 Flash Lid Spring  Replacement, Battery Door: step 1, image 1 of 1
      • Remove the M3 x 4mm screws from the bottom of your device as indicated by the picture. using the Philips Head J0 Screw Driver Bit .
      Ask FixBot
    2. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: step 2, image 1 of 1
      • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the left side of the device as indicated by the pictures.
      Ask FixBot
    3. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: step 3, image 1 of 1
      • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the right side of the device as indicated by the pictures.
      Ask FixBot
    4. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: step 4, image 1 of 2 Fujifilm FinePix S8630 Flash Lid Spring  Replacement: step 4, image 2 of 2
      • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the camera flash lid as indicated by the picture.
      • Remove the plastic cover from the flash lid by gentle pulling them apart or using the plastic opening tool.
      Ask FixBot
    5. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: step 5, image 1 of 1
      • Fold the lid down in order to access and remove the final M3 x 4mm screw using your Philips Head Screwdriver.
      Ask FixBot
    6. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: step 6, image 1 of 3 Fujifilm FinePix S8630 Flash Lid Spring  Replacement: step 6, image 2 of 3 Fujifilm FinePix S8630 Flash Lid Spring  Replacement: step 6, image 3 of 3
      • Use the plastic opening tool to pry the back and front casings of the camera apart.
      • Once pried apart use your hands to pull off the back plate of the camera.
      • You will need to apply a little bit of force to remove the back plate.
      Ask FixBot
    7. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: step 7, image 1 of 3 Fujifilm FinePix S8630 Flash Lid Spring  Replacement: step 7, image 2 of 3 Fujifilm FinePix S8630 Flash Lid Spring  Replacement: step 7, image 3 of 3
      • Once the back plate is removed twist the battery cover clockwise and it should easily dislodge.
      Ask FixBot
    1. Fujifilm FinePix S8630 Flash Lid Spring  Replacement, Flash Lid Spring: step 8, image 1 of 2 Fujifilm FinePix S8630 Flash Lid Spring  Replacement, Flash Lid Spring: step 8, image 2 of 2
      • Firmly grasp the flash bulb lid and remove the lid from the camera.
      Ask FixBot
    2. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: step 9, image 1 of 3 Fujifilm FinePix S8630 Flash Lid Spring  Replacement: step 9, image 2 of 3 Fujifilm FinePix S8630 Flash Lid Spring  Replacement: step 9, image 3 of 3
      Tool used on this step:
      Buy
      • Locate the spring and grasp with the tweezers.
      • Pinch and compress the spring to remove it from the camera housing.
      • Slide the lever that was holding the spring out of the camera housing.
      Ask FixBot
Colton Lancsarics
731 Reputation
6 Guides authored
USF Tampa, Team 3-2, Sullivan Spring 2016 Member of USF Tampa, Team 3-2, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G2
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 90
All Time: 816
