Up to 20% off select tools
LCD Screen Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
5
Past 7 Days:
28
Past 30 Days:
140
All Time:
1,360
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 45 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
In this guide, you will be taught how to successfully replace the LCD screen on your camera.
    1. LCD Screen  Replacement, Battery Door: step 1, image 1 of 1
      • Remove the M3 x 4mm screws from the bottom of your device as indicated by the picture. using the Philips Head J0 Screw Driver Bit .
      Ask FixBot
    2. LCD Screen  Replacement: step 2, image 1 of 1
      • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the left side of the device as indicated by the pictures.
      Ask FixBot
    3. LCD Screen  Replacement: step 3, image 1 of 1
      • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the right side of the device as indicated by the pictures.
      Ask FixBot
    4. LCD Screen  Replacement: step 4, image 1 of 2 LCD Screen  Replacement: step 4, image 2 of 2
      • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the camera flash lid as indicated by the picture.
      • Remove the plastic cover from the flash lid by gentle pulling them apart or using the plastic opening tool.
      Ask FixBot
    5. LCD Screen  Replacement: step 5, image 1 of 1
      • Fold the lid down in order to access and remove the final M3 x 4mm screw using your Philips Head Screwdriver.
      Ask FixBot
    6. LCD Screen  Replacement: step 6, image 1 of 3 LCD Screen  Replacement: step 6, image 2 of 3 LCD Screen  Replacement: step 6, image 3 of 3
      • Use the plastic opening tool to pry the back and front casings of the camera apart.
      • Once pried apart use your hands to pull off the back plate of the camera.
      • You will need to apply a little bit of force to remove the back plate.
      Ask FixBot
    7. LCD Screen  Replacement: step 7, image 1 of 3 LCD Screen  Replacement: step 7, image 2 of 3 LCD Screen  Replacement: step 7, image 3 of 3
      • Once the back plate is removed twist the battery cover clockwise and it should easily dislodge.
      Ask FixBot
    1. LCD Screen  Replacement, LCD Screen: step 8, image 1 of 3 LCD Screen  Replacement, LCD Screen: step 8, image 2 of 3 LCD Screen  Replacement, LCD Screen: step 8, image 3 of 3
      • Gently pull the tab out of the motherboard and then the LCD screen should easily be removed.
      Ask FixBot
Author
with
Colton Lancsarics
731 Reputation
6 Guides authored
USF Tampa, Team 3-2, Sullivan Spring 2016 Member of USF Tampa, Team 3-2, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G2
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 28
Past 30 Days: 140
All Time: 1,360
