Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Dremel 8220 won’t power on
Your Dremel 8220 won’t power on, completely unresponsive.
The battery may not be charged
The Dremel 8220 requires 1 hour of charging time to reach its full capacity. The battery has a relatively short usage time and can lose power during long periods of not being used. Attempt to recharge the battery back, it may take longer than the recommended 1 hour charge time.
The device might not be connected with the battery
The battery has to be properly inserted and the device and must make good contact for the Dremel to work. Ensure both the battery and the contact points of the device are clean. If the battery seems to be in good shape then continue to other possible problems.
The power switch might be broken
This component can break over time with use. This component may require fixing or complete replacement if not functioning properly. If this is your issue, refer to our power switch replacement guide.
The motor might be burnt out
If all of the other components are in working order then you may have a burnt out motor. This will require a motor replacement. If this is your issue, refer to our motor replacement guide.
Failure to charge
Battery pack will not accept a charge from the charger.
The battery pack may not be fully connected to the charger
The battery pack might not be making good contact with the charger. Ensure the contact point are clean on the battery and charger. Make sure battery is fully inserted into charger
The battery pack may be faulty
Try device with a different battery if available, if this fixes device then replace the battery.
My bit can’t be inserted
You attempted to insert an attachment into the collet but it will not accept a bit.
Collet or collet nut may be too tight
The collet inside of the collet nut can get worn out with heavy use. The collet can also be corroded or it could be very dirty, not allowing it to open enough to accept a bit. If you suspect the collet nut is on too tight, try punching out the collet from the collet nut. Once removed, make sure the collect is in good working condition. If this is your issue, refer to our collet replacement guide
The gear lock button might be broken
The shaft lock button will not lock, therefore, you are unable to change the tightness of the collet nut, the spring in lock button could be dislodged or broken. If the button will not return when you release it, the spring is most likely dislodged or broken in this case as well. if this is your issue, refer to our gear lock button replacement guide
The Dremel won’t work at high speeds
The Dremel will only work at low speeds. The device is unresponsive to changes in the speed selector switch.
Faulty wiring in speed selector switch
If the device will turn on and it is working, but the speed cannot be changed, the speed selector switch may be broken. Check to see if the wiring of the speed selector seems to be correct.
Motor could be damaged
If the speed selector switch is okay the issue may be the motor. Consider replacing the motor if other easier solutions do not solve your device’s issues. If this is your issue, refer to our motor replacement guide.
Device could be dirty
Dust and debris can build up inside of the Dremel affecting the performance of the internal parts. Over time, this can put stress on the motor and cause it to break down. If the device seems to be dirty internally, remove as much debris as possible and see if issues persist.
Battery almost dead
If the speed selector switch and motor seem to be in working order your battery may be the issue. Give the battery a full charge and see if the problem is fixed.
Author
with
Shailing Santiago
406 Reputation
2 Guides authored
18 Comments
I’ve owned two of these and both quit working simultaneously. The first one died in about a month because it couldn’t charge and the other one just quit working and can’t be turned on or charged though the light is permanently on, I wouldn’t have bought another one if I knew it would basically turn into a nightlight until the battery runs out in about a year.
angelasaurusrex - Reply Share
Brand new 8220 shuts off after about 3 seconds. Even though battery indicates full charge.
Margaret Lim - Reply Share
I’m having the same issue where my Brand new 8220 shuts off at a couple seconds. Battery shows a complete charge.
Tina Coffman - Reply Share
Follow the directions I posted below, it worked for me I had the same issues
Tyler D - Reply Share
Directions below should solve the issue... Hopefully. That is if you haven't already thrown the unit at the wall in frustration. I know I almost did.
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 118
All Time: 21,010
