Up to 20% off select tools
Dremel 8220 Power Switch Replacement
Views: 3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
22
Past 30 Days:
113
All Time:
3,002
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Needs More Images
A few more images would make this guide's procedures crystal clear.
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Tools
Introduction
Go to step 1 ↓
This guide will show you how to open up your device. You will then have access to all the internal components. The power switch can then be replaced with minimal effort
    1. Dremel 8220 Power Switch Replacement, Power Switch: step 1, image 1 of 1
      • Locate the battery at the back of your Dremel. Firmly grasp the battery on both sides and pull. It should easily come out of the battery well.
      Ask FixBot
    2. Dremel 8220 Power Switch Replacement: step 2, image 1 of 1
      • Remove the ring located around the speed selector switch by pulling apart on either side. This should require very minimal force.
      Ask FixBot
    3. Dremel 8220 Power Switch Replacement: step 3, image 1 of 1
      • Remove the collar wrench by pushing the gear lock button. Continue to hold this button as you rotate the wrench counter-clockwise until it is removed.
      Ask FixBot
    4. Dremel 8220 Power Switch Replacement: step 4, image 1 of 1
      • Remove the metal clasp from the battery well. This piece helps hold the plastic shell of the device together. Pry it out by gently applying some force with a screwdriver.
      Ask FixBot
    5. Dremel 8220 Power Switch Replacement: step 5, image 1 of 3 Dremel 8220 Power Switch Replacement: step 5, image 2 of 3 Dremel 8220 Power Switch Replacement: step 5, image 3 of 3
      • Remove five T9 Torx screws from the side of the tool.
      • Now pull apart the plastic shell of the device. If you are not able to, review the previous steps as you may have missed one.
      Ask FixBot
    6. Dremel 8220 Power Switch Replacement: step 6, image 1 of 1
      • Remove the faulty power switch. It should come out of the device without using any force.
      Ask FixBot
4 other people completed this guide.
Author
with
Shailing Santiago
406 Reputation
2 Guides authored
1 Guide Comment
Awesome!! Thanks!
christooher t - Reply Share
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 113
All Time: 3,002
