Up to 20% off select tools
Dremel 8220 Motor Replacement
Views: 6.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
32
Past 30 Days:
127
All Time:
6,288
Comments: 3
3 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Tools
Introduction
Go to step 1 ↓
This guide will show you how to replace a defective motor. With a few steps and a some tools, you will be able to open up the device and gain access to the motor. The motor can then be easily swapped out for a new one so that it can start working again.
    1. Dremel 8220 Motor Replacement, Motor: step 1, image 1 of 1
      • Locate the battery at the back of your Dremel. Firmly grasp the battery on both sides and pull. It should easily come out of the battery well.
      Ask FixBot
    2. Dremel 8220 Motor Replacement: step 2, image 1 of 1
      • Remove the ring located around the speed selector switch by pulling apart on either side. (This should require very minimal force.)
      Ask FixBot
    3. Dremel 8220 Motor Replacement: step 3, image 1 of 1
      • Remove the collar wrench by pushing the gear lock button. Continue to hold this button as you rotate the wrench counter-clockwise until it is removed.
      Ask FixBot
    4. Dremel 8220 Motor Replacement: step 4, image 1 of 1
      • Remove the metal clasp from the battery well. This piece helps hold the plastic shell of the device together. Pry it out by gently applying some force with a spudger.
      Ask FixBot
    5. Dremel 8220 Motor Replacement: step 5, image 1 of 3 Dremel 8220 Motor Replacement: step 5, image 2 of 3 Dremel 8220 Motor Replacement: step 5, image 3 of 3
      • Remove five 10.5 mm Torx T9 screws.
      • Now pull apart the plastic shell of the device. If you are not able to, review the previous steps as you may have missed one.
      Ask FixBot
    6. Dremel 8220 Motor Replacement: step 6, image 1 of 2 Dremel 8220 Motor Replacement: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • Remove broken motor. Lift out the motor until you can see the wires that connect to it.
      • Remove the clips where the wires connect with the motor. This can be done with your fingers of a pair of tweezers.
      • You should then be able to reconnect a new motor and reassemble the device.
      Ask FixBot
5 other people completed this guide.
Author
with
Shailing Santiago
406 Reputation
2 Guides authored
3 Guide Comments
Have you ever taken apart the motor? If so how?
Micky Ashey - Reply Share
Is there polarity correctness of the motor connections?
cal yoshikawa - Reply Share
Yes cal, the +ve (red) wire connects to the spade marked with a red dot.
qedelectrics - Reply Share
Past 24 Hours: 2
Past 7 Days: 32
Past 30 Days: 127
All Time: 6,288
