Dremel 8220 Gear Lock Button Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
Past 7 Days:
15
Past 30 Days:
100
All Time:
1,589
Comments: 3
3 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Introduction
Go to step 1 ↓
This guide will show you how to replace a defective gear lock button. With only a few steps and a few tools you will be able to open up the device and gain access to the faulty button. The button can then be easily swapped out for a new one.
Tools
    1. Dremel 8220 Gear Lock Button Replacement, Gear Lock Button: step 1, image 1 of 1
      • Locate the battery at the back of your Dremel. Firmly grasp the battery on both sides and pull. It should easily come out of the battery well.
      Ask FixBot
    2. Dremel 8220 Gear Lock Button Replacement: step 2, image 1 of 1
      • Remove the ring located around the speed selector switch by pulling apart on either side. This should require very minimal force.
      Ask FixBot
    3. Dremel 8220 Gear Lock Button Replacement: step 3, image 1 of 1
      • Remove the collar wrench by pushing the gear lock button. Continue to hold this button as you rotate the wrench counter-clockwise until it is removed.
      Ask FixBot
    4. Dremel 8220 Gear Lock Button Replacement: step 4, image 1 of 1
      • Remove the metal clasp from the battery well. This piece helps hold the plastic shell of the device together. Pry it out by gently applying some force with a screwdriver.
      Ask FixBot
    5. Dremel 8220 Gear Lock Button Replacement: step 5, image 1 of 3 Dremel 8220 Gear Lock Button Replacement: step 5, image 2 of 3 Dremel 8220 Gear Lock Button Replacement: step 5, image 3 of 3
      • Remove the 5 torx screws using a t9 screwdriver head.
      • Now pull apart the plastic shell of the device. If you are not able to, review the previous steps as you may have missed one.
      Ask FixBot
    6. Dremel 8220 Gear Lock Button Replacement: step 6, image 1 of 1
      • Remove the faulty gear lock button. It should come out of the device easily with no force needed.
      Ask FixBot
connor anisko
312 Reputation
2 Guides authored
3 Guide Comments
I’m assuming the issue I have is a faulty gear-lock button (that, or the locking gear that it restricts when depressed). If so, did you find a replacement button from the manufacturer? In my experience, they rarely offer repair parts themselves.
Robert - Reply Share
I also don’t understand why there was a flag claiming that this should be broken into separate guides. People aren’t THAT stupid, I hope.
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 100
All Time: 1,589
