Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Contour Roam2 Troubleshooting
Released in 2012, Identified by model number 1800K
Camera Does Not Capture Clear Pictures or Video
The picture quality of the camera is blurry or spotty.
Rotating Lens Cover Is Scratched or Damaged
The picture quality of the camera could be lessened if the lens cover is scratched. The lens cover can become scratched or damaged through normal use, especially if its owner takes it a variety of places. You can follow this guide to learn how to replace the lens cover.
Camera Will Not Attach To Mount
The camera will not stay mounted, or falls off the mount easily.
Camera Mount is Broken or Damaged
If your Contour Roam2 will not stay mounted, it could be because the mount has become broken or damaged. This can happen if the camera is bumped while mounted during vigorous activity. To replace the mount on the camera, you can follow this guide.
Camera Will Not Record Properly
The camera will not record video, or will not upload video correctly to a computer.
Record Slider is Broken
One reason your Contour Roam2 might not record properly is if the record slider is broken. This can happen if the camera is bumped while attached to a helmet, for example. If this is the case, then you can learn how to replace the record slider by following this guide.
Back Door Is Broken
Another reason your Contour Roam2 might not record properly is if the back door is broken, since the record button is contained on the back door. To learn how to replace the back door of the Contour Roam2, you can follow this guide.
Camera Takes Dark Photos
The camera takes dark or all-black photos.
Lens Unit is Broken or Damaged
If your Contour Roam2 camera is taking dark or all-black photos, it could be because the lens unit is damaged or broken. This can happen if the camera is treated roughly while in use. To learn how to replace a broken lens unit on the Contour Roam2, you can follow this guide.
Author
with
Chris
1 Reputation
0 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 35
All Time: 1,797
