Up to 20% off select tools
Contour Roam2 Back Door Replacement
Views: 2.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
20
Past 30 Days:
93
All Time:
2,546
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
This guide will give you step-by-step instructions on how to replace the back door on your Contour Roam2. Follow this guide if it is damaged or the stays button is no longer working.
    1. Contour Roam2 Back Door Replacement, Record Slider: step 1, image 1 of 1
      • Using the phillips head screwdriver (PH000) locate and remove the 4.45mm (.175in) screw by the 180 degree graphic on the metal ring.
      • The screws in the camera are very small and can strip very easily. Apply consistent pressure when removing screws.
      Ask FixBot
    2. Contour Roam2 Back Door Replacement: step 2, image 1 of 2 Contour Roam2 Back Door Replacement: step 2, image 2 of 2
      • Rotate the metal ring counterclockwise until completely removed.
      Ask FixBot
    3. Contour Roam2 Back Door Replacement: step 3, image 1 of 2 Contour Roam2 Back Door Replacement: step 3, image 2 of 2
      • Using the phillips head screwdriver (PH000) remove the two 4.46mm (.175in) screws on each side near the back of the camera.
      Ask FixBot
    4. Contour Roam2 Back Door Replacement: step 4, image 1 of 3 Contour Roam2 Back Door Replacement: step 4, image 2 of 3 Contour Roam2 Back Door Replacement: step 4, image 3 of 3
      • Grab the camera on both sides and slide the outer shell forward until completely removed.
      Ask FixBot
    5. Contour Roam2 Back Door Replacement: step 5, image 1 of 1
      • Lift the record slider out.
      • The record slider should come out easily no matter the position (forward or backward).
      Ask FixBot
    1. Contour Roam2 Back Door Replacement, Mounting Piece: step 6, image 1 of 2 Contour Roam2 Back Door Replacement, Mounting Piece: step 6, image 2 of 2
      • Using the phillips head screwdriver (PH000) remove the two 3.82mm (0.150in) screws on the bottom of mounting piece near the tripod screw-in.
      Ask FixBot
    2. Contour Roam2 Back Door Replacement: step 7, image 1 of 2 Contour Roam2 Back Door Replacement: step 7, image 2 of 2
      • Open the back door by your thumb and index finger on sides of back door and pull upward.
      Ask FixBot
    3. Contour Roam2 Back Door Replacement: step 8, image 1 of 1
      • Using your thumb, pry sides outward on back of mount piece.
      • This will loosen mount piece for removal in proceeding step.
      • Side can be hard to pry outward. Using a flat tool such as a metal spudger, may help if your thumb is insufficient.
      Ask FixBot
    4. Contour Roam2 Back Door Replacement: step 9, image 1 of 2 Contour Roam2 Back Door Replacement: step 9, image 2 of 2
      • Remove and replace mount piece.
      Ask FixBot
    1. Contour Roam2 Back Door Replacement, Back Door: step 10, image 1 of 1
      • Using a paper clip or a SIM eject tool size 0.8, push the metal bar out from the spring located on bottom of back door.
      • After removing the metal bar, the spring will become loose and may fall out on its own.
      Ask FixBot
    2. Contour Roam2 Back Door Replacement: step 11, image 1 of 1
      • Remove and replace back door.
      • Door should easily be removed by pulling away from main body of camera.
      • As door is being pulled away, the spring may fall out own its own.
      Ask FixBot
Author
with
Jamie Maple
310 Reputation
2 Guides authored
1 Guide Comment
Where can I get a replacement back door for an original contour roam shipped international? Contour will not reapond to my requests.
The Dude - Reply Share
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 93
All Time: 2,546
