Contour Roam2 Waterproof Action Camera Record Slider Replacement
  1. Contour Roam2 Waterproof Action Camera Record Slider Replacement, Record Slider: step 1, image 1 of 1
    • Using the phillips head screwdriver (PH000) locate and remove the 4.45mm (.175in) screw by the 180 degree graphic on the metal ring.
    • The screws in the camera are very small and can strip very easily. Apply consistent pressure when removing screws.
    Ask FixBot
  2. Contour Roam2 Waterproof Action Camera Record Slider Replacement: step 2, image 1 of 2 Contour Roam2 Waterproof Action Camera Record Slider Replacement: step 2, image 2 of 2
    • Rotate the metal ring counterclockwise until completely removed.
    Ask FixBot
  3. Contour Roam2 Waterproof Action Camera Record Slider Replacement: step 3, image 1 of 2 Contour Roam2 Waterproof Action Camera Record Slider Replacement: step 3, image 2 of 2
    • Using the phillips head screwdriver (PH000) remove the two 4.46mm (.175in) screws on each side near the back of the camera.
    Ask FixBot
  4. Contour Roam2 Waterproof Action Camera Record Slider Replacement: step 4, image 1 of 3 Contour Roam2 Waterproof Action Camera Record Slider Replacement: step 4, image 2 of 3 Contour Roam2 Waterproof Action Camera Record Slider Replacement: step 4, image 3 of 3
    • Grab the camera on both sides and slide the outer shell forward until completely removed.
    Ask FixBot
  5. Contour Roam2 Waterproof Action Camera Record Slider Replacement: step 5, image 1 of 1
    • Lift the record slider out.
    • The record slider should come out easily no matter the position (forward or backward).
    Ask FixBot
3 other people completed this guide.
Matthew Kofsky
548 Reputation
3 Guides authored
2 Guide Comments
I have had this camera since I was 16 I am 21 now and there was something wrong with the slider I am glad I didn't get rid of it! Because of you it is fixed now!!!
Neiko Rivera (Specters) - Reply Share
Dose anyone know if there is an equivalent guide but for the “Contour +2”?
Christopher Hinrichs - Reply Share
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 42
All Time: 1,415
