Up to 20% off select tools
Contour Roam2 Rotating Lens Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
91
All Time:
1,565
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Tools
  • Phillips #000 Screwdriver
    4.9
  • Spudger
    4.9
Introduction
Go to step 1 ↓
This guide will give you step-by-step instructions on how to replace the rotating lens cover on your Contour Roam2. Follow this guide if the lens been scratched or damaged.
    1. Contour Roam2 Rotating Lens Replacement, Rotating Lens: step 1, image 1 of 1
      • Using the phillips head screwdriver (PH000) locate and remove the 4.45mm (.175in) screw by the 180 degree graphic on the metal ring.
      • The screws in the camera are very small and can strip very easily. Apply consistent pressure when removing screws.
      Ask FixBot
    2. Contour Roam2 Rotating Lens Replacement: step 2, image 1 of 2 Contour Roam2 Rotating Lens Replacement: step 2, image 2 of 2
      • Rotate the metal ring counterclockwise until completely removed.
      Ask FixBot
    3. Contour Roam2 Rotating Lens Replacement: step 3, image 1 of 1
      • Use a spudger to pry up the black rubber ring around the lens cover.
      • The black rubber ring is vey thin and can easily tear. Use caution when removing.
      Ask FixBot
    4. Contour Roam2 Rotating Lens Replacement: step 4, image 1 of 1
      • Remove and replace the lens cover.
      Ask FixBot
Author
with
Matthew Kofsky
548 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 91
All Time: 1,565
