Contour Roam2 Mounting Piece Replacement
    1. Contour Roam2 Mounting Piece Replacement, Record Slider: step 1, image 1 of 1
      • Using the phillips head screwdriver (PH000) locate and remove the 4.45mm (.175in) screw by the 180 degree graphic on the metal ring.
      • The screws in the camera are very small and can strip very easily. Apply consistent pressure when removing screws.
      Ask FixBot
    2. Contour Roam2 Mounting Piece Replacement: step 2, image 1 of 2 Contour Roam2 Mounting Piece Replacement: step 2, image 2 of 2
      • Rotate the metal ring counterclockwise until completely removed.
      Ask FixBot
    3. Contour Roam2 Mounting Piece Replacement: step 3, image 1 of 2 Contour Roam2 Mounting Piece Replacement: step 3, image 2 of 2
      • Using the phillips head screwdriver (PH000) remove the two 4.46mm (.175in) screws on each side near the back of the camera.
      Ask FixBot
    4. Contour Roam2 Mounting Piece Replacement: step 4, image 1 of 3 Contour Roam2 Mounting Piece Replacement: step 4, image 2 of 3 Contour Roam2 Mounting Piece Replacement: step 4, image 3 of 3
      • Grab the camera on both sides and slide the outer shell forward until completely removed.
      Ask FixBot
    5. Contour Roam2 Mounting Piece Replacement: step 5, image 1 of 1
      • Lift the record slider out.
      • The record slider should come out easily no matter the position (forward or backward).
      Ask FixBot
    1. Contour Roam2 Mounting Piece Replacement, Mounting Piece: step 6, image 1 of 2 Contour Roam2 Mounting Piece Replacement, Mounting Piece: step 6, image 2 of 2
      • Using the phillips head screwdriver (PH000) remove the two 3.82mm (0.150in) screws on the bottom of mounting piece near the tripod screw-in.
      Ask FixBot
    2. Contour Roam2 Mounting Piece Replacement: step 7, image 1 of 2 Contour Roam2 Mounting Piece Replacement: step 7, image 2 of 2
      • Open the back door by your thumb and index finger on sides of back door and pull upward.
      Ask FixBot
    3. Contour Roam2 Mounting Piece Replacement: step 8, image 1 of 1
      • Using your thumb, pry sides outward on back of mount piece.
      • This will loosen mount piece for removal in proceeding step.
      • Side can be hard to pry outward. Using a flat tool such as a metal spudger, may help if your thumb is insufficient.
      Ask FixBot
    4. Contour Roam2 Mounting Piece Replacement: step 9, image 1 of 2 Contour Roam2 Mounting Piece Replacement: step 9, image 2 of 2
      • Remove and replace mount piece.
      Ask FixBot
3 other people completed this guide.
Matthew Kofsky
548 Reputation
3 Guides authored
2 Guide Comments
Hi i need this part...
julmarte - Reply Share
I Need a battery, and check up.
Too many small screws for me, I am using it on a home defense air powered 50 cal with orange top. need to have a mount for that Ball Shooter. where can I get that project I live in the 831 AC
Or is their something used already working I got this needing a battery.
Help from a Person I can mail it
Thanks Dudley
Dudley Walsh - Reply Share
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 29
All Time: 1,950
