Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Camera Will Not Turn On
The camera will not power up after pressing the power button.
Bad/Discharged Battery
Double check that the battery is installed. Try charging the battery. If the battery does not charge replace the battery.
Dirty Battery Contacts
There may be debris preventing a good connection between the camera and the battery. Clean the battery contacts with a cotton swab or a pencil eraser.
Loose Connections
The internal ribbon cables may be loose and need to be re-seated. Open up your camera and check for any loose ribbon connections using this guide.
Faulty Camera
If the camera is still not powering on, you may need to replace the motherboard using this guide.
Buttons Don't Seem to Work.
The camera doesn't register button presses or registers them multiple times when pressed.
Sticky Button
If liquids or dirt have spilled onto the camera, the contact may be filled with gunk (official electronics term). Take the camera's back casing off and clean the contacts with a cotton swab or a pencil eraser. A light solvent such as rubbing alcohol may be required. Use this guide to access the contacts.
Loose/Faulty Ribbon Connector
The connection from the contact unit to the motherboard may need to be re-seated or replaced. Use this guide to access the ribbon connector.
Faulty Contact Unit
The board that registers button input may have malfunctioned. Replace it using this guide.
Lens Deployment/Retraction Mechanism Failure
The lens will not deploy when the camera is powered on, or will not retract when powered off.
Lens Mechanism Jammed/Misaligned
Inspect the lens. Does it look symmetrical or is one side sticking out farther than another? It may be possible to gently pull while powering up the camera to snap it back in place. Or power it down while gently pushing. Too much force can damage the mechanism, so be careful.
Gunk in the Lens Mechanism
Sticky beverage residue and debris can build up in the lens mechanism causing it to stick. Without taking the camera apart try cleaning around the edges of the lens using a cotton swap and a light solvent (rubbing alcohol works great).
Defective/Damaged Lens Mechanism
You've tried everything else. Time to replace the lens mechanism using this guide.
LCD display is not functioning correctly/won’t turn on
Camera indicates that it is on, but an abnormal image or nothing at all appears on the display.
No Image Displayed
Your display may be turned off. Try pressing the display button until the display turns on. If this does not work you may need to replace your LCD display using this guide.
Dim Screen
Out of direct sunlight check to see if the image is still dim. Check the brightness setting for the screen. Turn it up until it is bright enough to see. If not then the back lighting of the LCD screen has burnt out and the LCD should be replaced using this guide.
Horizontal Lines Appear
This indicates that the LCD is damaged. Replace it using this guide.
Cracked
The LCD is visibly damaged but may still display partial images, it is recommended that it be replaced before it fails completely re-seat if necessary using this guide.
Flash Unit Isn’t Working
The flash doesn't fire when taking a picture.
The Flash Isn't Turned On.
Verify the flash is on in the menu settings. The flash (ON) symbol should be displayed on the viewfinder display.
Bad Connection
The ribbon cable connecting the flash unit to the motherboard might be disconnected or loose. Check to make sure the cable is properly connected and using this guide.
Bad Flash Bulb
The flash bulb might be burnt out. A new flash bulb will need to be installed using this guide.
Jeff Casper
897 Reputation
7 Guides authored
USF Tampa, Team 17-5, Blackwell Fall 2016 Member of USF Tampa, Team 17-5, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G5
3 Members
84 Guides authored
1 Comment
My Powershot SD1200IS Image Stableizer (IS) seems to shut off when the flash is off. Can this be set not to happen? My IS is currently set to continuous, but without the flash on or on auto, all pictures are blurry.
carpenterpierce - Reply Share
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 73
All Time: 4,688
