Canon PowerShot SD1200 IS Lens Assembly Replacement
Views: 5K
View statistics:
Past 24 Hours:
6
Past 7 Days:
45
Past 30 Days:
241
All Time:
4,974
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 30 minutes
Difficulty: Moderate
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Introduction
Go to step 1 ↓
Damaging the lens on your camera can be a death sentence. But never fear, if you have an old compatible Canon camera you can cannibalize, or find a good part elsewhere, restoring your camera to working order is relatively simple.
Tools
    1. Canon PowerShot SD1200 IS Lens Assembly Replacement, Front and Rear Covers: step 1, image 1 of 1
      • Remove the battery.
      Ask FixBot
    2. Canon PowerShot SD1200 IS Lens Assembly Replacement: step 2, image 1 of 3 Canon PowerShot SD1200 IS Lens Assembly Replacement: step 2, image 2 of 3 Canon PowerShot SD1200 IS Lens Assembly Replacement: step 2, image 3 of 3
      • Remove the two screws from the side of the camera casing with the strap. (4mm Phillips 00)
      • Remove the two screws from the bottom of the camera. (4mm Phillips 00)
      • Remove the two screws from the right side of the camera opposite the strap. (2mm Phillips 00)
      Ask FixBot
    3. Canon PowerShot SD1200 IS Lens Assembly Replacement: step 3, image 1 of 2 Canon PowerShot SD1200 IS Lens Assembly Replacement: step 3, image 2 of 2
      • Pull off the front cover.
      • If the top of the cover sticks, use gentle downward pressure on the retention clips above the lens to release.
      • Remove the back cover.
      Ask FixBot
    1. Canon PowerShot SD1200 IS Lens Assembly Replacement, LCD: step 4, image 1 of 3 Canon PowerShot SD1200 IS Lens Assembly Replacement, LCD: step 4, image 2 of 3 Canon PowerShot SD1200 IS Lens Assembly Replacement, LCD: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Use the spudger to lift the retaining flap on the Zero Insertion Force (ZIF) tab securing the thick ribbon cable.
      • Slide out the ribbon cable using fingers or tweezers.
      • Be sure you are prying up on the hinged retaining flap, not the connector.
      • Using tweezers, disconnect the small ribbon cable below the flash assembly from the No Fuss Connector by simply pulling the ribbon cable straight out.
      Ask FixBot
    2. Canon PowerShot SD1200 IS Lens Assembly Replacement: step 5, image 1 of 3 Canon PowerShot SD1200 IS Lens Assembly Replacement: step 5, image 2 of 3 Canon PowerShot SD1200 IS Lens Assembly Replacement: step 5, image 3 of 3
      • Remove the L shaped brackets from the left and right side of the LCD screen with the spudger tool.
      • The Brackets have tabs that need to be pried up.
      • Remove the screw below the shutter button. (2.5mm Phillips 00)
      • Holding the sides of the LCD screen, lift the screen up and away to remove.
      Ask FixBot
    1. Canon PowerShot SD1200 IS Lens Assembly Replacement, Flash Assembly: step 6, image 1 of 3 Canon PowerShot SD1200 IS Lens Assembly Replacement, Flash Assembly: step 6, image 2 of 3 Canon PowerShot SD1200 IS Lens Assembly Replacement, Flash Assembly: step 6, image 3 of 3
      • Use the spudger to pry up each side of the lens assembly Flat-Topped Connector at the bottom of the motherboard.
      • Holding back the lens assembly ribbon cable, use the spudger to lift the Zero Insertion Force (ZIF) connector tab . Slide out the ribbon cable.
      • Be sure you are prying up on the hinged retaining flap, not the connector itself.
      • Use the spudger to lift the Zero Insertion Force (ZIF) connector tab located on the flash unit. Remove the ribbon cable.
      Ask FixBot
    2. Canon PowerShot SD1200 IS Lens Assembly Replacement: step 7, image 1 of 1
      • Remove the two screws (2 mm Phillips 00) along the back edge of the camera frame directly behind the flash assembly.
      Ask FixBot
    3. Canon PowerShot SD1200 IS Lens Assembly Replacement: step 8, image 1 of 1
      • Lift out the flash assembly.
      Ask FixBot
    1. Canon PowerShot SD1200 IS Lens Assembly Replacement, Lens Assembly: step 9, image 1 of 1
      • Use the spudger to gently pry up both sides of the flat-topped connector, then lift the cable directly up out of its socket.
      Ask FixBot
    2. Canon PowerShot SD1200 IS Lens Assembly Replacement: step 10, image 1 of 1
      • Remove the 4 corner screws on the back of the camera in silver metal frame surrounding the back of the lens assembly (2.5 mm Phillips 00) .
      Ask FixBot
    3. Canon PowerShot SD1200 IS Lens Assembly Replacement: step 11, image 1 of 1
      • Use the spudger to gently lift out the LED at the top of the lens assembly.
      Ask FixBot
    4. Canon PowerShot SD1200 IS Lens Assembly Replacement: step 12, image 1 of 1
      • Remove the lens assembly.
      Ask FixBot
5 other people completed this guide.
Jeff Casper
897 Reputation
7 Guides authored
USF Tampa, Team 17-5, Blackwell Fall 2016 Member of USF Tampa, Team 17-5, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G5
3 Members
84 Guides authored
2 Guide Comments
i have this same camera, and for me all the sudden it stopped focasing completely. everything else works, and it isnt in any weird modes. when i try to focas especially on auto focas with the half button push, i hear some abnormal clicking like it is trying to auto focas but cant. im not sure what to do!
Katelyn Lehmann - Reply Share
I have the same problem after my camera sat unused for a year. Everything functions fine except the camera will not focus.
ROGER - Reply Share
Past 24 Hours: 6
Past 7 Days: 45
Past 30 Days: 241
All Time: 4,974
