Canon PowerShot SD1200 IS Function Button Board Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
12
Past 30 Days:
83
All Time:
729
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Introduction
Go to step 1 ↓
Use this guide to replace the function buttons on the back of the camera.
Tools
    1. Canon PowerShot SD1200 IS Function Button Board Replacement, Front and Rear Covers: step 1, image 1 of 1
      • Remove the battery.
      Ask FixBot
    2. Canon PowerShot SD1200 IS Function Button Board Replacement: step 2, image 1 of 3 Canon PowerShot SD1200 IS Function Button Board Replacement: step 2, image 2 of 3 Canon PowerShot SD1200 IS Function Button Board Replacement: step 2, image 3 of 3
      • Remove the two screws from the side of the camera casing with the strap. (4mm Phillips 00)
      • Remove the two screws from the bottom of the camera. (4mm Phillips 00)
      • Remove the two screws from the right side of the camera opposite the strap. (2mm Phillips 00)
      Ask FixBot
    3. Canon PowerShot SD1200 IS Function Button Board Replacement: step 3, image 1 of 2 Canon PowerShot SD1200 IS Function Button Board Replacement: step 3, image 2 of 2
      • Pull off the front cover.
      • If the top of the cover sticks, use gentle downward pressure on the retention clips above the lens to release.
      • Remove the back cover.
      Ask FixBot
    1. Canon PowerShot SD1200 IS Function Button Board Replacement, Function Buttons: step 4, image 1 of 1
      • Use the spudger to lift the tab on the Zero Insertion Force (ZIF) connector located at the top of the function button board.
      • Be sure you are prying up on the hinged retaining flap, not the connector itself.
      • Slide out the ribbon cable from the connector.
      Ask FixBot
    2. Canon PowerShot SD1200 IS Function Button Board Replacement: step 5, image 1 of 1
      • Remove the top screw from the function button board. (3.5mm Phillips 00)
      • Remove the bottom screw from the function button board. (2.5mm Phillips 00)
      Ask FixBot
    3. Canon PowerShot SD1200 IS Function Button Board Replacement: step 6, image 1 of 1
      • Lift out the function button board.
      Ask FixBot
Jeff Casper
897 Reputation
7 Guides authored
USF Tampa, Team 17-5, Blackwell Fall 2016 Member of USF Tampa, Team 17-5, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G5
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 83
All Time: 729
