Canon PowerShot SD1200 IS Motherboard
  1. Canon PowerShot SD1200 IS Motherboard, Front and Rear Covers: step 1, image 1 of 1
    • Remove the battery.
    Ask FixBot
  2. Canon PowerShot SD1200 IS Motherboard: step 2, image 1 of 3 Canon PowerShot SD1200 IS Motherboard: step 2, image 2 of 3 Canon PowerShot SD1200 IS Motherboard: step 2, image 3 of 3
    • Remove the two screws from the side of the camera casing with the strap. (4mm Phillips 00)
    • Remove the two screws from the bottom of the camera. (4mm Phillips 00)
    • Remove the two screws from the right side of the camera opposite the strap. (2mm Phillips 00)
    Ask FixBot
  3. Canon PowerShot SD1200 IS Motherboard: step 3, image 1 of 2 Canon PowerShot SD1200 IS Motherboard: step 3, image 2 of 2
    • Pull off the front cover.
    • If the top of the cover sticks, use gentle downward pressure on the retention clips above the lens to release.
    • Remove the back cover.
    Ask FixBot
  4. Canon PowerShot SD1200 IS Motherboard, Motherboard: step 4, image 1 of 1
    • Remove the microphone connector by gripping it with the tool and gently, with a wiggling motion, pull it out.
    • Pull the connector straight out by the white connector. Pulling on the wires will damage them.
    Ask FixBot
  5. Canon PowerShot SD1200 IS Motherboard: step 5, image 1 of 1
    • Lift off the mechanical shutter button assembly.
    Ask FixBot
  6. Canon PowerShot SD1200 IS Motherboard: step 6, image 1 of 2 Canon PowerShot SD1200 IS Motherboard: step 6, image 2 of 2
    • Use the spudger to lift the tab on the Zero Insertion Force (ZIF) connector located at the bottom of the motherboard.
    • Be sure you are prying up on the hinged retaining flap, not the connector itself.
    • Slide out the ribbon cable.
    • Use the spudger to pry up each side of the Flat-Topped Connectors
    Ask FixBot
  7. Canon PowerShot SD1200 IS Motherboard: step 7, image 1 of 1
    • Remove the press fit ribbon cable by prying upward with spudger tool.
    • It is not necessary to remove the Lens or Flash Assemblies to remove the motherboard.
    Ask FixBot
  8. Canon PowerShot SD1200 IS Motherboard: step 8, image 1 of 1
    • Remove the bottom right screw from the motherboard. (4mm Phillips 00)
    • Remove top and lower left black screws from the motherboard. (2.5mm Phillips 00)
    Ask FixBot
  9. Canon PowerShot SD1200 IS Motherboard: step 9, image 1 of 1
    • Lift out the motherboard.
    Ask FixBot
Jeff Casper
897 Reputation
7 Guides authored
USF Tampa, Team 17-5, Blackwell Fall 2016 Member of USF Tampa, Team 17-5, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G5
3 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 47
All Time: 770
