Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Notebook Will Not Turn On or Stay On
Battery May Be Broken or Not Charging
If the laptop powers on when the charger is connected, but fails to power on or stay on when disconnected, then your battery may need to be replaced. Follow the battery guide for removal.
Battery Will Not Retain Its Charge
The battery should have close to 7 hours of power. If the battery loses power quicker then it use to, or does takes much longer than normal to charge, it may need to be replaced. Follow the battery guide for removal.
Power Adapter May Be Failing
If the laptop still does not power on with the adapter plugged in, then the adapter may be failing. Consider replacing the adapter.
Screen Will Not Turn On
Screen Remains Black After Powering On, Is Discolored, or Is Cracked
If any of these problems are affecting your screen, consider replacing it. Follow the screen guide for removal.
Inputs Will Not Respond
Keys Are Not Responding
If the keys are not responding, the keyboard is probably faulty. Consider replacing the whole keyboard. Follow the keyboard guide for removal.
Individual Keys Are Failing
If individual keys are failing, there may be objects obstructing the typing. Consider cleaning the keyboard. Follow the keyboard guide for removal.
Trackpad Unresponsive or Touchy
If the trackpad is not moving your on-screen cursor appropriately, the trackpad may need to be replaced. Follow the trackpad guide for removal.
Programs Crashing or Slow Computer
Computer Is Not Running as Expected
If your computer is running much slower than normal while programs are open or if your programs turn off unexpectedly, your motherboard may need to be replaced. Follow the motherboard guide for removal.
Data Loss
Issues Saving and Storing Items or Folders
If saved items and folders are not being stored properly, or if they are disappearing altogether, your hard drive may need to be replaced. Follow the hard drive guide for removal.
Cracked Casing
Case Around Monitor
If your case that borders the screen is broken, follow the screen case guide for removal.
Becca Day
321 Reputation
2 Guides authored
Clemson, Team 7-4, Benson Spring 2016 Member of Clemson, Team 7-4, Benson Spring 2016
CLEM-BENSON-S16S7G4
5 Members
84 Guides authored
1 Comment
Hi. The camera on my ASUS 1015E doesn't work. I notice that it doesn't appear on the BIOS setup. I tried to fix it by updating the BIOS, but still not works. Help, please!
Chepe Bourdet - Reply Share
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 48
All Time: 1,064
