Asus 1015E-DS03 Front Screen Trim Replacement
    1. Asus 1015E-DS03 Front Screen Trim Replacement, Battery: step 1, image 1 of 1
      • Hold the laptop using both hands with the battery facing upwards.
      Ask FixBot
    2. Asus 1015E-DS03 Front Screen Trim Replacement: step 2, image 1 of 1
      • Push the two tabs located below the battery in towards each other using your thumbs.
      Ask FixBot
    3. Asus 1015E-DS03 Front Screen Trim Replacement: step 3, image 1 of 1
      • Push the battery upwards and out of the laptop as shown.
      Ask FixBot
    4. Asus 1015E-DS03 Front Screen Trim Replacement: step 4, image 1 of 1
      • Continue to push the battery upwards until it is completely separated from the laptop as shown.
      Ask FixBot
    1. Asus 1015E-DS03 Front Screen Trim Replacement, Front Screen Case: step 5, image 1 of 1
      • Push up on the back of the tabs that cover the hinges connecting the screen to the base of the laptop.
      • While pushing up on the back of the tabs, insert the spudger into the opening created from pushing on the tabs until the tab detaches.
      Ask FixBot
    2. Asus 1015E-DS03 Front Screen Trim Replacement: step 6, image 1 of 2 Asus 1015E-DS03 Front Screen Trim Replacement: step 6, image 2 of 2
      • Once the case has been separated from the laptop, pull the case off completely, using the plastic opening tool or your fingers.
      • You will hear popping noises which are to be expected.
      Ask FixBot
    3. Asus 1015E-DS03 Front Screen Trim Replacement: step 7, image 1 of 1
      • When the screen case has been successfully removed, the laptop should resemble the photo shown here.
      Ask FixBot
2 other people completed this guide.
Becca Day
321 Reputation
2 Guides authored
Clemson, Team 7-4, Benson Spring 2016 Member of Clemson, Team 7-4, Benson Spring 2016
CLEM-BENSON-S16S7G4
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 38
All Time: 1,032
