Asus 1015E-DS03 Keyboard Replacement
    1. Asus 1015E-DS03 Keyboard Replacement, Battery: step 1, image 1 of 1
      • Hold the laptop using both hands with the battery facing upwards.
      Ask FixBot
    2. Asus 1015E-DS03 Keyboard Replacement: step 2, image 1 of 1
      • Push the two tabs located below the battery in towards each other using your thumbs.
      Ask FixBot
    3. Asus 1015E-DS03 Keyboard Replacement: step 3, image 1 of 1
      • Push the battery upwards and out of the laptop as shown.
      Ask FixBot
    4. Asus 1015E-DS03 Keyboard Replacement: step 4, image 1 of 1
      • Continue to push the battery upwards until it is completely separated from the laptop as shown.
      Ask FixBot
    1. Asus 1015E-DS03 Keyboard Replacement, Keyboard: step 5, image 1 of 1
      • Once the battery is removed, unscrew the highlighted 3mm screws (4) using a #0 Phillps head screwdriver.
      • Be very careful not to lose the screws, these four screws are very small.
      Ask FixBot
    2. Asus 1015E-DS03 Keyboard Replacement: step 6, image 1 of 2 Asus 1015E-DS03 Keyboard Replacement: step 6, image 2 of 2
      • After all four screws are removed, flip the laptop over with the keyboard facing up.
      • Use a spudger to pry up where the keyboard is attached to the laptop on all sides until it is detached from the laptop.
      • It is normal to hear cracking noises when prying off the keyboard.
      • After keyboard is detached from laptop, there is a ribbon cable still attached to the motherboard. See next step before completely removing keyboard.
      Ask FixBot
    3. Asus 1015E-DS03 Keyboard Replacement: step 7, image 1 of 1
      • After the keyboard is detached, the ribbon cable which connects the keyboard to the laptop's motherboard is exposed.
      • Be careful not to tear or rip the ribbon cable.
      Ask FixBot
    4. Asus 1015E-DS03 Keyboard Replacement: step 8, image 1 of 1
      • Using the spudger push the white clips upwards that are holding the cable.
      Ask FixBot
    5. Asus 1015E-DS03 Keyboard Replacement: step 9, image 1 of 2 Asus 1015E-DS03 Keyboard Replacement: step 9, image 2 of 2
      • Gently pull the strip out of the square slot.
      Ask FixBot
2 other people completed this guide.
Joe Capriola
494 Reputation
3 Guides authored
Clemson, Team 7-4, Benson Spring 2016 Member of Clemson, Team 7-4, Benson Spring 2016
CLEM-BENSON-S16S7G4
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 118
All Time: 1,765
