Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Echo won't turn on
The Amazon Echo won't power on and doesn't respond to commands.
Not plugged in properly
Make sure the power cord is fully inserted into the bottom of the Echo and the cord fits into the groove at the back of the device. Also, be sure that the power adapter is correctly plugged into a working outlet.
Faulty power cord
The power cord may have a short or a broken wire. Check the cord for any frayed or damaged areas. If any damage is found, replace the power cord.
Faulty power and speaker driver board
The circuit board that manages power within the Echo may be broken. This requires a replacement of the board.
Faulty motherboard
If the motherboard malfunctions, none of the speaker's functions may work, requiring a replacement of the motherboard.
Won't connect to Wi-Fi
The Echo isn't connecting to your wireless network. This is indicated by the power LED above the power cord being solidly lit orange, and/or an oscillating violet light ring at the top.
The Echo is too far away
Try moving the Echo closer to your Wi-Fi router. Also, moving the Echo away from walls and interference sources like microwaves and baby monitors may help.
Your Wi-Fi password is incorrect
If your Wi-Fi network is password protected, make sure you enter the right password. Your Wi-Fi password is case-sensitive.
Broken Wi-Fi module
The Wi-Fi module on your Echo's motherboard may be broken, so you may need to replace the motherboard.
Router issues
The issue may lie with your Wi-Fi router. If this is the case, try the following:
Reboot your router
Turn off your router for 30 seconds, then turn it back on. Be careful, as this will disconnect any devices you have connected to your Wi-Fi.
Reboot your router, letting the Echo reconnect first
Turn off your router for 30 seconds and turn off Wi-Fi on all your connected devices. Then, turn the router back on and let the Echo connect to your Wi-Fi. Once the Echo is connected, reconnect all other devices to your Wi-Fi.
Won't connect to Bluetooth
The Echo isn't paired with your Bluetooth device, so you are unable to stream music from your device to the Echo or control it with your phone.
Your device is too far away
Make sure your device is within 30 feet of the Echo or they may not be able to communicate.
Bluetooth is not enabled on your device
Make sure your device supports Bluetooth connections and that the Bluetooth setting for your device is on.
Your device is not paired with the Echo
Check in your Bluetooth settings menu to see if your device is paired with the Echo. If it's not, say "Alexa, pair," and choose the Amazon Echo from the list in the Bluetooth menu on your device.
Broken Bluetooth module
The Bluetooth module on your Echo's motherboard may be broken, so you may need to replace the motherboard.
No Sound
The Echo is on and connected, but won't make a peep.
The Echo is muted
The Echo may be muted without your knowledge. Try turning up the volume by rotating the volume ring at the top clockwise.
Blown out or broken speakers
If you've been jamming out to your tunes a bit too loud, your speakers may have blown out, or may have been broken otherwise. You'll need to replace both speakers, the woofer and the tweeter.
The same circuit board that manages power within the Echo also manages the audio output. If this is broken, you'll need to replace the board.
Distorted sound
Your Echo plays music and listens to your commands, but sounds too tinny, too bass heavy, or otherwise distorted.
Broken tweeter
If your music sounds too bass heavy, your tweeter may need to be replaced.
Broken woofer
If the Echo sounds too high pitched, your woofer may be broken and needs to be replaced.
If the sound is distorted in some other way, try replacing the power and speaker driver board, as it may be malfunctioning.
Light ring not working
Your Echo works almost perfectly, but no matter what it's doing, the light ring at the top won't turn on.
Faulty LED/Microphone board
The LED's or their drivers may not be working properly, requiring a replacement of the LED/Microphone board.
The Echo doesn't hear you
No matter how much you yell at it and even if you press the action button to wake it, the Echo can't hear a thing you say.
The microphones are off
The Echo has the ability to turn off its microphone array. If the microphones are off, the light ring at the top should be lit red. To turn them back on, simply press the microphone button at the top of the Echo.
The microphone array in the Echo may have malfunctioned, in which case the LED/Microphone board should be replaced.
Author
with
Alexander Albert
1,169 Reputation
6 Guides authored
USF Tampa, Team 3-3, Wollert Spring 2016 Member of USF Tampa, Team 3-3, Wollert Spring 2016
USFT-WOLLERT-S16S3G3
4 Members
72 Guides authored
86 Comments
How do I disconnect a iPhone 6s from Echo? Every time I get a call or text message it sends the sound notification through the Echo speaker. I would like to turn this function off
Bob - Reply Share
Echo will not connect with Amazon My Music. In fact, my Echo will not do ANYTHING. Seriously considering returning it.
iamronny - Reply Share
My Echo keeps saying no music in your library, I have Spotify and music on it
pauline.johnson54 - Reply Share
You need to set Spotify as the default music app in your Alexa app
Oliver Bristow - Reply Share
I bought my amazon echo a few days ago and you have to speak loudly at it to make it hear you, crap
Saltie Seal - Reply Share
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 117
All Time: 248,189
