Up to 20% off select tools
Amazon Echo Tweeter Assembly Replacement
Views: 4.7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
23
Past 30 Days:
103
All Time:
4,720
Comments: 10
7 comments on steps, 3 guide comments.
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide demonstrates how to replace the tweeter assembly in the Amazon Echo. Removing the assembly is a prerequisite for replacing the tweeter or woofer.
    1. Amazon Echo Tweeter Assembly Replacement, Power and Speaker Driver Board: step 1, image 1 of 1
      • Power off and unplug your Echo before disassembly. Failure to do so could result in injury or damage to the device.
      • Peel off the rubber footing from the bottom of the Echo.
      • Do not pull the rubber footing too hard, as it could stretch out of shape. Use a spudger to help remove the foot if you have any trouble.
      Ask FixBot
    2. Amazon Echo Tweeter Assembly Replacement: step 2, image 1 of 3 Amazon Echo Tweeter Assembly Replacement: step 2, image 2 of 3 Amazon Echo Tweeter Assembly Replacement: step 2, image 3 of 3
      • Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo.
      Ask FixBot
    3. Amazon Echo Tweeter Assembly Replacement: step 3, image 1 of 1
      • Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
      Ask FixBot
    4. Amazon Echo Tweeter Assembly Replacement: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
      • Tugging on the wires may damage the device. Pull from the plastic connectors instead.
      Ask FixBot
    5. Amazon Echo Tweeter Assembly Replacement: step 5, image 1 of 2 Amazon Echo Tweeter Assembly Replacement: step 5, image 2 of 2
      • Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
      • Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
      Ask FixBot
    6. Amazon Echo Tweeter Assembly Replacement: step 6, image 1 of 3 Amazon Echo Tweeter Assembly Replacement: step 6, image 2 of 3 Amazon Echo Tweeter Assembly Replacement: step 6, image 3 of 3
      • Using the spudger, pull back the two plastic clips on the plate.
      • Lift the board up and pull it away from the plate.
      Ask FixBot
    1. Amazon Echo Tweeter Assembly Replacement, Tweeter Assembly: step 7, image 1 of 2 Amazon Echo Tweeter Assembly Replacement, Tweeter Assembly: step 7, image 2 of 2
      • Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
      Ask FixBot
    2. Amazon Echo Tweeter Assembly Replacement: step 8, image 1 of 1
      • Peel off the black fabric wrapped around the Echo.
      • Be careful not to rip the fabric. Use a spudger to help remove the adhesive if you have any trouble.
      Ask FixBot
    3. Amazon Echo Tweeter Assembly Replacement: step 9, image 1 of 3 Amazon Echo Tweeter Assembly Replacement: step 9, image 2 of 3 Amazon Echo Tweeter Assembly Replacement: step 9, image 3 of 3
      • Remove the four 42.8 mm T10 Torx screws around the tweeter.
      • Lift the tweeter and its attached housing from the device.
      Ask FixBot
Author
with
Alexander Albert
1,169 Reputation
6 Guides authored
USF Tampa, Team 3-3, Wollert Spring 2016 Member of USF Tampa, Team 3-3, Wollert Spring 2016
USFT-WOLLERT-S16S3G3
4 Members
72 Guides authored
3 Guide Comments
I've gotten this far, but where do you get a replacement? No brand or model # on tweeter.
Kyle - Reply Share
Are you saying removing it and replacing the same tweeter is what you have to do? It says no parts.
kathy1557 - Reply Share
The primary purpose of this guide is to show you how to remove a failing tweeter so that you can replace it with a new one. The "no parts required" text appears at the top of this guide because the author didn't have a source for the replacement part.
Ron Davis - Reply Share
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 103
All Time: 4,720
