Up to 20% off select tools
Amazon Echo Woofer Replacement
Views: 9.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
18
Past 30 Days:
111
All Time:
9,056
Comments: 10
7 comments on steps, 3 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will show you how to replace the woofer, the speaker in the Amazon Echo responsible for the low-frequency bass. This guide should be helpful if your Echo is lacking bass or sounds otherwise distorted.
    1. Amazon Echo Woofer Replacement, Power and Speaker Driver Board: step 1, image 1 of 1
      • Power off and unplug your Echo before disassembly. Failure to do so could result in injury or damage to the device.
      • Peel off the rubber footing from the bottom of the Echo.
      • Do not pull the rubber footing too hard, as it could stretch out of shape. Use a spudger to help remove the foot if you have any trouble.
      Ask FixBot
    2. Amazon Echo Woofer Replacement: step 2, image 1 of 3 Amazon Echo Woofer Replacement: step 2, image 2 of 3 Amazon Echo Woofer Replacement: step 2, image 3 of 3
      • Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo.
      Ask FixBot
    3. Amazon Echo Woofer Replacement: step 3, image 1 of 1
      • Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
      Ask FixBot
    4. Amazon Echo Woofer Replacement: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
      • Tugging on the wires may damage the device. Pull from the plastic connectors instead.
      Ask FixBot
    5. Amazon Echo Woofer Replacement: step 5, image 1 of 2 Amazon Echo Woofer Replacement: step 5, image 2 of 2
      • Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
      • Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
      Ask FixBot
    6. Amazon Echo Woofer Replacement: step 6, image 1 of 3 Amazon Echo Woofer Replacement: step 6, image 2 of 3 Amazon Echo Woofer Replacement: step 6, image 3 of 3
      • Using the spudger, pull back the two plastic clips on the plate.
      • Lift the board up and pull it away from the plate.
      Ask FixBot
    1. Amazon Echo Woofer Replacement, Tweeter Assembly: step 7, image 1 of 2 Amazon Echo Woofer Replacement, Tweeter Assembly: step 7, image 2 of 2
      • Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
      Ask FixBot
    2. Amazon Echo Woofer Replacement: step 8, image 1 of 1
      • Peel off the black fabric wrapped around the Echo.
      • Be careful not to rip the fabric. Use a spudger to help remove the adhesive if you have any trouble.
      Ask FixBot
    3. Amazon Echo Woofer Replacement: step 9, image 1 of 3 Amazon Echo Woofer Replacement: step 9, image 2 of 3 Amazon Echo Woofer Replacement: step 9, image 3 of 3
      • Remove the four 42.8 mm T10 Torx screws around the tweeter.
      • Lift the tweeter and its attached housing from the device.
      Ask FixBot
    1. Amazon Echo Woofer Replacement, Woofer: step 10, image 1 of 1
      • Lift the woofer out of the Echo.
      Ask FixBot
Author
with
Alexander Albert
1,169 Reputation
6 Guides authored
USF Tampa, Team 3-3, Wollert Spring 2016 Member of USF Tampa, Team 3-3, Wollert Spring 2016
USFT-WOLLERT-S16S3G3
4 Members
72 Guides authored
3 Guide Comments
Where can you buy a replacement woofer?
adam mierzwa - Reply Share
My exact question.
Marty Koenig - Reply Share
Could you post the dimension of the woofer unit? Its depth and diameter (and possibly screw holes location/diameter)? That would be very useful. Thank you.
No Body - Reply Share
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 111
All Time: 9,056
