No Display on Screen
Your display screen should show you information such as incoming calls, waiting calls, missed calls, as well as date and time of missed calls. If you are unable to see any of the features listed above, you may have a problem with your display screen .
Dead Batteries
If you cannot see anything displaying on the screen, it may be due to
dead batteries. Replacing the four existing AA batteries may solve this problem. Refer to "ATT CL2940 Batteries Replacement Guide" for more details on how to do so.
Bad Connection Between Telephone and Wall Jack
If batteries are not the issue, the problem may be due to a bad connection between the telephone and wall jack. Power is drawn from the phone line, so make sure that both ends of the phone line are secured in both the phone jack in the wall and in the handset. If the jack is not working, refer to ''ATT_CL2940 Phone Jack Replacement'' for replacing jack.
Broken Screen
If the above two situations are solved and the screen is still not displaying, the problem may be due to the screen itself. Replacing the screen can solve this problem. Replacing broken screen is a technical and complex work, please contact your provider to fix it.
Numbers dialed are not showing up on the screen
While dialing a number, you should be able to see the numbers being dialed on the display and hear a tone in your headset. If that does not happen, you might have a problem with your keypad.
Dead Batteries
This telephone operates during a power failure if a telephone line cord is
plugged into the telephone wall jack and the telephone base. But you cannot see anything displaying on the screen. You are able to answer calls with the handset, and make calls using the dialing keys. No other features work unless batteries are installed. Refer to "ATT CL2940 Batteries Replacement Guide" for more details on how to do so.
Broken Buttons
When you click the button and do not see the numbers appear on the screen or can hear a tone, it may because the buttons used for dialing are broken. Replacing broken buttons can solve this problem. Refer to "ATT CL2940 Buttons and/or Keypad Replacement" for more details on how to do so.
The person on the other line cannot hear you or you cannot hear them
If you are unable to hear the person talking on the other line or they cannot hear you despite redialing or restarting the phone, you may have a problem with your handset.
Check Cord Connection
The problem might be due to poor connection between the headset and the phone itself. Ensure that the cord is securely connected at both ends. If the cord is connected, and the problem has not been fixed, you need to replace the cord. Refer to the "ATT CL2940 Handset Cord Replacement" for more details on how to do so.
Check Handset
If the problem still persists, it is due to an issue with the handset itself. Check the status of the speaker inside the handset. Refer to the "ATT CL2940 Headset Speaker Replacement" for further information.
No sound emits when phone is set to loudspeaker mode
If you put your phone on loudspeaker mode and you are unable to hear anything. You have a problem with your speakers.
Check Volume Level
After ensuring the device is turned on, make sure that the volume is not muted and the volume level is to an appropriate level.
Check Speakers
If your volume level is all the way up and you still can't hear any sounds, this might be due to an issue with the speaker. Replacing the speaker should solve this problem. Refer to the "ATT CL2940 Speakerphone Replacement".
Phone Book Issues
Your phone should be able to store up to 65 numbers and names in the phone book memory. There is a problem if your saved numbers disappear from your phone book or you are no longer able to store additional numbers.
Check Memory Capacity
If your phone can no longer save more numbers, this can be because you have reached the full memory capacity. To solve this problem you will have to delete unwanted numbers from your phone book. Refer to "AT&T Corded Telephone User Manual" for more details on how to do so. The related content is on pages 20-24.
Without Installing Batteries or Telephone Line Immediately
If you neither install batteries nor a telephone line, after a few minutes, the
telephone clears the directory, caller ID history, speed dial memory, and the
last number dialed memory. Your saved numbers disappear may due to this reason. Please be quick when you are replacing batteries or a telephone line.
Author
with
Noor Assaf
312 Reputation
2 Guides authored
IUPUI, Team 1-1, Harley Spring 2016 Member of IUPUI, Team 1-1, Harley Spring 2016
IUPUI-HARLEY-S16S1G1
4 Members
84 Guides authored
12 Comments
How do you listen to your messages. Don't see a button or information on it.
thelma andrews - Reply Share
changed batteries but still no display - I have 2 of these phone and neither displays work
josey51rimrock - Reply Share
Please clean the battery contacts. When they are dirty even the brand new batteries do not work.
ptredei - Reply Share
Only get a busy signal when I plug the phone line in. Phone line works with other phone.
Peg Tileston - Reply Share
AT&T Caller I.D. Mod.CL842078S.My tel.will ring [normal 3x], followed by announcement 2xB.C. call, followed by irritating noise about 5 seconds, starts ring 19 times for 2 mins., followed by fax ring for 2 mins. What is the problem please give me a call.25038502334
Elizabeth MacPherson - Reply Share
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 32
All Time: 9,835
