ATT CL2940 Buttons and/or Keypad Replacement
    1. ATT CL2940 Buttons and/or Keypad Replacement, Back Panel: step 1, image 1 of 3 ATT CL2940 Buttons and/or Keypad Replacement, Back Panel: step 1, image 2 of 3 ATT CL2940 Buttons and/or Keypad Replacement, Back Panel: step 1, image 3 of 3
      • Remove five 9.5 mm Phillips #1 screws from the back panel of the phone.
      Ask FixBot
    2. ATT CL2940 Buttons and/or Keypad Replacement: step 2, image 1 of 3 ATT CL2940 Buttons and/or Keypad Replacement: step 2, image 2 of 3 ATT CL2940 Buttons and/or Keypad Replacement: step 2, image 3 of 3
      • Slide the metal spudger into the crack and continue around to the front panel of the phone.
      • Be careful not to break the clips that hold the back panel to the front panel.
      Ask FixBot
    3. ATT CL2940 Buttons and/or Keypad Replacement: step 3, image 1 of 1
      • When setting the back panel down, be careful to not rip any of the wires off of the internal components.
      Ask FixBot
    1. ATT CL2940 Buttons and/or Keypad Replacement, Buttons and/or Keypad: step 4, image 1 of 2 ATT CL2940 Buttons and/or Keypad Replacement, Buttons and/or Keypad: step 4, image 2 of 2
      • Unscrew five 5.6 mm screws on top level, yellow motherboard.
      Ask FixBot
    2. ATT CL2940 Buttons and/or Keypad Replacement: step 5, image 1 of 3 ATT CL2940 Buttons and/or Keypad Replacement: step 5, image 2 of 3 ATT CL2940 Buttons and/or Keypad Replacement: step 5, image 3 of 3
      • Lift the top level Motherboard in order to get to the lower level Motherboard.
      Ask FixBot
    3. ATT CL2940 Buttons and/or Keypad Replacement: step 6, image 1 of 2 ATT CL2940 Buttons and/or Keypad Replacement: step 6, image 2 of 2
      • Unscrew the 5.6 mm screw on the clip behind the Screen as shown.
      Ask FixBot
    4. ATT CL2940 Buttons and/or Keypad Replacement: step 7, image 1 of 2 ATT CL2940 Buttons and/or Keypad Replacement: step 7, image 2 of 2
      • Unscrew five 5.6 mm screws on the lower level Motherboard.
      • Keep the screws for the upper and lower level motherboard separated.
      Ask FixBot
    5. ATT CL2940 Buttons and/or Keypad Replacement: step 8, image 1 of 2 ATT CL2940 Buttons and/or Keypad Replacement: step 8, image 2 of 2
      • Lift the lower level Motherboard upward.
      • Remove the silicon pad above the buttons.
      Ask FixBot
    6. ATT CL2940 Buttons and/or Keypad Replacement: step 9, image 1 of 2 ATT CL2940 Buttons and/or Keypad Replacement: step 9, image 2 of 2
      • Push the Button Panel upward and pull it out.
      • Replace the entire Button Panel or a single defective button.
      Ask FixBot
4 other people completed this guide.
Charles Messmore
577 Reputation
5 Guides authored
IUPUI, Team 1-1, Harley Spring 2016 Member of IUPUI, Team 1-1, Harley Spring 2016
IUPUI-HARLEY-S16S1G1
4 Members
84 Guides authored
1 Guide Comment
Great explanation! Where would you recommend buying replacement buttons for the phone? Thanks
Sean Richardson - Reply Share
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 29
All Time: 973
