ATT CL2940 Phone Jack Replacement
    1. ATT CL2940 Phone Jack Replacement, Back Panel: step 1, image 1 of 3 ATT CL2940 Phone Jack Replacement, Back Panel: step 1, image 2 of 3 ATT CL2940 Phone Jack Replacement, Back Panel: step 1, image 3 of 3
      • Remove five 9.5 mm Phillips #1 screws from the back panel of the phone.
      Ask FixBot
    2. ATT CL2940 Phone Jack Replacement: step 2, image 1 of 3 ATT CL2940 Phone Jack Replacement: step 2, image 2 of 3 ATT CL2940 Phone Jack Replacement: step 2, image 3 of 3
      • Slide the metal spudger into the crack and continue around to the front panel of the phone.
      • Be careful not to break the clips that hold the back panel to the front panel.
      Ask FixBot
    3. ATT CL2940 Phone Jack Replacement: step 3, image 1 of 1
      • When setting the back panel down, be careful to not rip any of the wires off of the internal components.
      Ask FixBot
    1. ATT CL2940 Phone Jack Replacement, Phone Jack: step 4, image 1 of 2 ATT CL2940 Phone Jack Replacement, Phone Jack: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Using the precision tweezers, bend the golden tips of the green and red wires upward.
      • The wires are pulled out from two of the six holes. Make sure you remember which holes you pulled the wires out from.
      • Bend the wires slowly and gently to avoid breaking them.
      Ask FixBot
    2. ATT CL2940 Phone Jack Replacement: step 5, image 1 of 3 ATT CL2940 Phone Jack Replacement: step 5, image 2 of 3 ATT CL2940 Phone Jack Replacement: step 5, image 3 of 3
      • After bending the golden wire tips, pull the wires out from the back side of the phone jack.
      Ask FixBot
Noor Assaf
312 Reputation
2 Guides authored
IUPUI, Team 1-1, Harley Spring 2016 Member of IUPUI, Team 1-1, Harley Spring 2016
IUPUI-HARLEY-S16S1G1
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 24
All Time: 1,091
