Up to 20% off select tools
Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The Wen 2307 Rotary tool has a variety of uses from grinding, cutting, sanding and drilling. Rust removal from metal and smooth out wood with great efficiency. It contains a strong 1 Amp motor and adjustable speed ranging from 8,000 – 30,000 RPM. The entire Wen 2307 kit includes: 2 Drill Bits, 2 Collets, 2 Mandrels, 1 Drum Sander, 4 Sander Bands, 20 Cut-Off Wheels, 1 Dressing Stone, 54 Sanding Disks, 10 Grinding Stones, 2 High Speed Cutters, 2 Felt Polishing Wheels, Bit Changing Wrench and the main Variable Speed Rotary tool.
Identification
It can be identified by the Wen label on the side.
Additional Information
Wen Replacement parts
Wen Rotary Tool page
Wen contact information
WEN 2307 Variable Speed Rotary Tool Operator's Manual
WEN 2307 Variable Speed Rotary Tool User Manual
Author
with
Sergio Palacio
458 Reputation
2 Guides authored
USF Tampa, Team 12-1, Eyestone Spring 2016 Member of USF Tampa, Team 12-1, Eyestone Spring 2016
USFT-EYESTONE-S16S12G1
4 Members
72 Guides authored
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 86
All Time: 4,564
