Wen 2307 Speed Adjustment Assembly Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
96
All Time:
1,393
Comments: 1
1 comment on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If the device is not changing speed it may be because of a broken speed adjuster.
Tools
    1. Wen 2307 Speed Adjustment Assembly Replacement, Front Panel: step 1, image 1 of 1
      • Unscrew the locking sleeve.
      Ask FixBot
    2. Wen 2307 Speed Adjustment Assembly Replacement: step 2, image 1 of 1
      • Remove the hanging clip.
      Ask FixBot
    3. Wen 2307 Speed Adjustment Assembly Replacement: step 3, image 1 of 2 Wen 2307 Speed Adjustment Assembly Replacement: step 3, image 2 of 2
      • Unscrew the six 8mm PH2 screws.
      Ask FixBot
    4. Wen 2307 Speed Adjustment Assembly Replacement: step 4, image 1 of 1
      • While pressing the spindle lock button, unscrew the collet nut and remove it along with the brass collet.
      Ask FixBot
    5. Wen 2307 Speed Adjustment Assembly Replacement: step 5, image 1 of 1
      • To remove the front panel, pry the device apart while holding the device with the other hand.
      • The front panel should come out easily.
      Ask FixBot
    1. Wen 2307 Speed Adjustment Assembly Replacement, Power Cable: step 6, image 1 of 2 Wen 2307 Speed Adjustment Assembly Replacement, Power Cable: step 6, image 2 of 2
      • Identify the screws.
      • Unscrew the two 3mm phillips PH2.
      • Don't forget to put them appart from the ones unscrewed before.
      • Phillips PH2
      • Flathead 2.5mm
      Ask FixBot
    2. Wen 2307 Speed Adjustment Assembly Replacement: step 7, image 1 of 1
      • Remove the place boar carefully.
      Ask FixBot
    3. Wen 2307 Speed Adjustment Assembly Replacement: step 8, image 1 of 1
      • Pull out the power cable connectors.
      Ask FixBot
    4. Wen 2307 Speed Adjustment Assembly Replacement: step 9, image 1 of 1
      • Pull out the cord sleve for the new cable replacement.
      Ask FixBot
    1. Wen 2307 Speed Adjustment Assembly Replacement, Speed Adjustment Assembly: step 10, image 1 of 1
      • Remove the connected wiring from the circuit board.
      Ask FixBot
    2. Wen 2307 Speed Adjustment Assembly Replacement: step 11, image 1 of 1
      • Remove the single 4mm screw retaining the circuit board.
      Ask FixBot
    3. Wen 2307 Speed Adjustment Assembly Replacement: step 12, image 1 of 1
      • Gently pry the circuit board from the back piece.
      Ask FixBot
2 other people completed this guide.
Dominick Chavez
137 Reputation
1 Guide authored
USF Tampa, Team 12-1, Eyestone Spring 2016 Member of USF Tampa, Team 12-1, Eyestone Spring 2016
USFT-EYESTONE-S16S12G1
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 96
All Time: 1,393
