Up to 20% off select tools
Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The Samsung Powerbot R9250 is a robotic vacuum cleaner released in 2018 by Samsung Electronics. It is part of the R9000 series of Powerbots and is a higher-end device. The R9250 has a suction power of 30 watts, a 90 minute battery life, a 12.2-inch brush, and a .7 L dust bin. Moreover, the R9250 has Wi-Fi connectivity, meaning that it can be controlled via voice control and the Amazon Alexa.
Although a vacuum cleaner, the R9250 is distinct from others due to its circular design and its robotic operation. The hands-free cleaning is accomplished by the R9250 through its onboard camera and its multiple sensors that allow the vacuum cleaner to determine the ideal cleaning path for multi-room cleaning, while avoiding obstacles along the way. Moreover, users can see where all the Powerbot has cleaned through the coverage map viewed through Samsung’s Smart Home Application. Users can also schedule the Powerbot to clean through this application.
Identification
This device can be identified by model number R9250.
Technical Specifications
  • Key Features:
    • Wi-Fi Connectivity: Yes
    • Visionary Mapping™: Yes
    • Point Cleaning: Yes
    • Brush Type: Combo: Yes
    • Remote: Yes
    • EasyPass™ Wheels: Yes
    • FullView Sensor™Yes
    • Suction: Up to 30W
    • Bagless: Yes
    • Dust Capacity: 0.7 L
    • Brush Width: 12.2"
    • Filter (Exhaust): Yes
    • CycloneForce™ Technology: Yes
    • Multi-Surface Cleaning: Yes
    • Sensor: FullView Sensor™
    • Brush Type: Combo
    • Navigation: Visionary Mapping Plus
    • Cliff Sensor: Yes
    • Auto Docking: Yes
  • Convenience:
    • Cleaning Speed: 32cm/sec
    • Dust Sensor: Yes
    • Display: 7-Segment
    • Additional Tools: Cleaning Tool, Extra Filter, Magnetic Tape
    • Convenience Feature: Point Cleaning
    • Running Time: ≤ 90 MIN
    • Running Time (Max): ≤ 90 MIN
    • Running Time (Min): ≤ 30 MIN
    • Washable Filter: Yes
  • Weight & Dimensions:
    • Product Dimensions: 14.88" x 5.31" x 14.25"
    • Shipping Dimensions: 7.2" D x 20.9" H x 18.7" W
    • Product Weight: 10.5 lbs
    • Shipping Weight: 16.5 lbs
Additional Information
Product Page
User Manual
Full Specifications
Comparison of Powerbot 9000 series
Samsung POWERbot R9250 Robot Vacuum Specifications
Author
with
Ethen Sanchez
552 Reputation
5 Guides authored
Cal Poly, Team 10-3, Banghart Winter 2017 Member of Cal Poly, Team 10-3, Banghart Winter 2017
CPSU-BANGHART-W17S10G3
3 Members
60 Guides authored
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 42
All Time: 5,778
