Up to 20% off select tools
Samsung Powerbot R9250 Wheel Replacement
Views: 3.6K
View statistics:
Past 24 Hours:
5
Past 7 Days:
26
Past 30 Days:
108
All Time:
3,609
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If your Samsung Powerbot R9250 is struggling to move, dragging on one side, or making unusual noises, a worn or damaged wheel may be the cause. This guide will walk you through the steps to safely remove and replace a wheel on your Powerbot R9250, restoring smooth movement and proper performance.
Before beginning, power off the vacuum and disconnect it from its charging base. Work on a clean, flat surface to prevent small parts from rolling away. With the right tools and careful handling, you can replace the wheel and get your robot vacuum running like new.
    1. Samsung Powerbot R9250 Wheel Replacement, Wheel: step 1, image 1 of 1
      • Flip the Powerbot onto its side so that the wheel you plan to remove is facing upward. This will give you clear access to the wheel assembly and the surrounding plastic housing.
      Ask FixBot
    2. Samsung Powerbot R9250 Wheel Replacement: step 2, image 1 of 1
      • Remove the round white cap located on the outside of the wheel. This cap protects the internal screw and must be removed before accessing the wheel mount.
      Ask FixBot
    3. Samsung Powerbot R9250 Wheel Replacement: step 3, image 1 of 1
      • Use a spudger or prying tool to carefully lift and remove the white plastic casing that wraps around the back section of the vacuum. Work slowly around the edges to avoid cracking the plastic.
      Ask FixBot
    4. Samsung Powerbot R9250 Wheel Replacement: step 4, image 1 of 1
      • Continue prying until the entire white casing separates from the vacuum body. Set the casing aside in a safe place.
      Ask FixBot
    5. Samsung Powerbot R9250 Wheel Replacement: step 5, image 1 of 1
      • On the wheel you are replacing, locate the small square opening on the black protective layer surrounding the wheel. Inside this opening is the wheel’s mounting screw. Use the appropriate driver to remove this screw completely. Keep the screw — you will need it to install the new wheel.
      Ask FixBot
    6. Samsung Powerbot R9250 Wheel Replacement: step 6, image 1 of 2 Samsung Powerbot R9250 Wheel Replacement: step 6, image 2 of 2
      • Use a spudger or prying tool to gently lift the black protective layer away from the wheel. Once the layer is loose, pull the wheel straight out of its housing. Your wheel is now removed and ready to be replaced.
      Ask FixBot
Author
with
Ethen Sanchez
552 Reputation
5 Guides authored
Cal Poly, Team 10-3, Banghart Winter 2017 Member of Cal Poly, Team 10-3, Banghart Winter 2017
CPSU-BANGHART-W17S10G3
3 Members
60 Guides authored
1 Guide Comment
Hi Ethen. I've recently replaced both wheel kits on the same model powerbot you are working on in this guide. When I turn it on now it becomes absolutely possessed. Goes much faster than normal and moved erratically. I am wondering if you have ever experienced this or have heard of this.
Cameron Curran - Reply Share
Past 24 Hours: 5
Past 7 Days: 26
Past 30 Days: 108
All Time: 3,609
