Up to 20% off select tools
The Samsung Powerbot R9250 is identified by model number R9250. It was released in 2018.
Error code C03 shows up everytime
what should i do? The thing doesn't even follow any route anymore it just goes wherever it wants
1 Comment:
I've had this issue. To clarify the answer below, I seem to get items stuck behind the wheel/ square lug which attaches to the gearbox. The below youtube video shows taking it apart. You can also order a replacement wheel assembly as the motors do appear to start going out as well (and there isn't an easy way to get them).
https://www.youtube.com/watch?v=8jQlBv0e...
by Share
Add a comment
1 Answer
The C03 error code on a Samsung POWERbot indicates that something is caught in the right driving wheel. You can clear the error by clearing the obstruction.
  1. Turn the power switch off that is located at the bottom before cleaning the robot.
  2. Use a blunt rod or tweezers to remove any foreign matter.
Add a comment
Add your answer
Lee Guang will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 53
All Time: 1,218
