Samsung Powerbot R9250 Battery Replacement
    1. Samsung Powerbot R9250 Battery Replacement, Battery: step 1, image 1 of 1
      • On the bottom of the bot, locate the battery lid along the curved edge of the bot.
      Ask FixBot
    2. Samsung Powerbot R9250 Battery Replacement: step 2, image 1 of 2 Samsung Powerbot R9250 Battery Replacement: step 2, image 2 of 2
      • Unscrew each of the two screws and remove the lid to expose the battery.
      Ask FixBot
    3. Samsung Powerbot R9250 Battery Replacement: step 3, image 1 of 1
      • Follow the wires to find the small white box next to the battery.
      Ask FixBot
    4. Samsung Powerbot R9250 Battery Replacement: step 4, image 1 of 1
      • On the side of the white box facing the battery, find the rigid tab.
      Ask FixBot
    5. Samsung Powerbot R9250 Battery Replacement: step 5, image 1 of 3 Samsung Powerbot R9250 Battery Replacement: step 5, image 2 of 3 Samsung Powerbot R9250 Battery Replacement: step 5, image 3 of 3
      • Push this tab into the white box, and pull the wires up. This releases the wire from the white box, allowing you to fully remove the battery.
      Ask FixBot
2 other people completed this guide.
Ethen Sanchez
552 Reputation
5 Guides authored
Cal Poly, Team 10-3, Banghart Winter 2017 Member of Cal Poly, Team 10-3, Banghart Winter 2017
CPSU-BANGHART-W17S10G3
3 Members
60 Guides authored
5 Guide Comments
This is what I needed to know. You are my life saver.
thank you.
Akiko Ohkawa - Reply Share
How do you know it’s time for a battery replacement? Mine starts up fine, but after 5 minutes suction drops to lowest setting.
James Morgan - Reply Share
Where can we a get a replacement battery, I could not find one anywhere.
Hari Krishna Gaddipati - Reply Share
I am looking for one also!
Julie Miller - Reply Share
I found one voltage but slightly higher wattage and it said that it was an upgrade but it lasted maybe 6 months and now doesn't want to take a charge. It tries to charge it. It's you know doing the lights pattern uphill but all it ever achieves is one Mark and if you tell it manually move or whatever with the remote control it doesn't do anything. It just sits there and perpetually tries to charge but only achieves one. Mark charge tried unplugging it for a long time and was an expensive battery like 140 bucks so I am reluctant to it did great while it ran but I couldn't find the exact battery. They were both I think 21.6 volts but the wattage was different. Who knows the battery just didn't last or won't take a charge now and I don't know maybe I mean it's trying too.
G in Dallas - Reply Share
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 29
All Time: 3,907
